when i m using pin 2 of UNO as interrupt pin it is working fine. But when I want to use A4 pin of UNO board as external interrupt using Pinchangeint.h library,but its not working.
#include "IRremote.h"
#include <PinChangeInt.h>
#define ARDUINOPIN A4
int receiver = A5;
IRrecv irrecv(receiver);
decode_results results;
#include <TimerOne.h>
volatile int i=0; // Variable to use as a counter
volatile boolean zero_cross=0; // Boolean to store a "switch" to tell us if we have crossed zero
int AC_pin = 10; // Output to Opto Triac
//int dim2 = 0; // led control
int dim = 128; // Dimming level (0-128) 0 = on, 128 = 0ff
int freqStep = 75; // This is the delay-per-brightness step in microseconds.
//Serial.begin(9600);
irrecv.enableIRIn(); // Start the IR receiver (classic remote)
pinMode(AC_pin, OUTPUT); // Set the Triac pin as output
pinMode(ARDUINOPIN, INPUT_PULLUP);
PCintPort::attachInterrupt(ARDUINOPIN, zero_cross_detect, RISING);
//attachPinChangeInterrupt(ARDUINOPIN, zero_cross_detect, RISING);
//attachInterrupt(0, zero_cross_detect, RISING); // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
Timer1.initialize(freqStep); // Initialize TimerOne library for the freq we need
//Timer1.attachPinChangeInterrupt(dim_check, freqStep);
Timer1.attachInterrupt(dim_check, freqStep);
void zero_cross_detect()
zero_cross = true; // set the boolean to true to tell our dimming function that a zero cross has occured
i=0;
digitalWrite(AC_pin, LOW);
// Turn on the TRIAC at the appropriate time
void dim_check()
if(zero_cross == true) {
if(i>=dim) {
digitalWrite(AC_pin, HIGH); // turn on light
i=0; // reset time step counter
zero_cross=false; // reset zero cross detection
else {
i++; // increment time step counter
void translateIR(int code) // takes action based on IR code received
switch(code)
case -24481:
DecreaseSpeed();
case 24735:
IncreaseSpeed();
if (irrecv.decode(&results)) // have we received an IR signal?
//Serial.println(results.value);
int code = results.value;
delay(200);
translateIR(code);
irrecv.resume();
void IncreaseSpeed(){
delay(200);
if (dim>5)
dim = dim - 8;
if (dim<0)
dim=0;
void DecreaseSpeed(){
delay(200);
if (dim<127)
dim = dim + 8;
if (dim>127)
dim=128;
reciver.ino (2.88 KB)
