I I continue to struggle with PIND.
I I wrote a simple sketch as an attempt to better understand PIND. In the sketch below, PIND reads my NANO's pin D4 state which is connected to a KY40 SW pin. I have independently confirmed this KY40 DOES have the switch button and it does work.
Question 1 :The PIND read correctly reads a button press as "0". But with no button press, PIND reads pinD4 as 16.
Where in the 16 coming from?
Question 2: Will PIND reads (with masking)affect subsequent PIND reads in the same sketch? I.e, are PIND reads i ndependent?
int pinSW=4;
int val;
pinMode(pinSW, INPUT_PULLUP);
val = PIND & 0b00010000;//read the button state (NANO pin D4)
//When no button push,the val read is 16 ??
//When Button pushed, val read is 0.
Serial.println(val);
