PinDefinitionsAndMore.h Not recognised
I'm a using SimpleReceiver.cpp IRremote 4.4.0 by shirriff and #include "PinDefinitionsAndMore.h" isn't recognized. When I compile it, it says:
C:\xxx\xxxx\AppData\Local\Temp.arduinoIDE-unsaved202479-19632-a06se0.b3wv\sketch_aug9a\sketch_aug9a.ino:71:10: fatal error: PinDefinitionsAndMore.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: PinDefinitionsAndMore.h: No such file or directory
I have no clue what to do. I added the most recent library to it, which I've checked to have the physical file in it, but it still won't recognize it. Anyone have an idea to fix this?
We have seen that bug here before and I also encountered it. The clue is in the path name, see where it says unsaved? Either manually save before compile, or do as most do and set preferences auto save to true.
How did you install the library? Do you have that file? Is it on your computer somewhere?
Ahhh..yes the new version sort of changed a lot. Post your whole sketch please, I used to include that file in a separate tab but with the library update, I didn't seem to need it after making the changes described here:
https://github.com/Arduino-IRremote/Arduino-IRremote#converting-your-2x-program-to-the-4x-version
Even invoking the library seems to have changed
#include <IRremote.h>
to
#include <IRremote.hpp>
It was all throughout one of the previous versions of the library, included in a separate tab of the same name and called in the main tab like:
#include "PinDefinitionsAndMore.h" // Define macros for input and output pin etc.
Found it on a backup I have before installing the 2.x.x Arduino IDE:
 *  PinDefinitionsAndMore.h
 *  Contains pin definitions for IRremote examples for various platforms
 *  as well as definitions for feedback LED and tone() and includes
 *  Copyright (C) 2021-2023  Armin Joachimsmeyer
 *  armin.joachimsmeyer@gmail.com
 *  This file is part of IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
 *  Arduino-IRremote is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
 *  See the GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program. If not, see <http://www.gnu.org/licenses/gpl.html>.
 * Pin mapping table for different platforms
 * Platform     IR input    IR output   Tone      Core/Pin schema
 * DEFAULT/AVR  2           3           4         Arduino
 * ATtinyX5     0|PB0       4|PB4       3|PB3     ATTinyCore
 * ATtiny167    3|PA3       2|PA2       7|PA7     ATTinyCore
 * ATtiny167    9|PA3       8|PA2       5|PA7     Digispark original core
 * ATtiny84      |PB2        |PA4        |PA3     ATTinyCore
 * ATtiny88     3|PD3       4|PD4       9|PB1     ATTinyCore
 * ATtiny3217  18|PA1      19|PA2      20|PA3     MegaTinyCore
 * ATtiny1604   2           3|PA5       %
 * ATtiny816   14|PA1      16|PA3       1|PA5     MegaTinyCore
 * ATtiny1614   8|PA1      10|PA3       1|PA5     MegaTinyCore
 * SAMD21       3           4           5
 * ESP8266      14|D5       12|D6       %
 * ESP32        15          4          27
 * ESP32-C3     6           7          10
 * BluePill     PA6         PA7       PA3
 * APOLLO3      11          12          5
 * RP2040       3|GPIO15    4|GPIO16    5|GPIO17
//#define _IR_MEASURE_TIMING // For debugging purposes.
#if defined(__AVR__)
#if defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__) // Digispark board. For use with ATTinyCore.
#include "ATtinySerialOut.hpp" // TX is at pin 2 - Available as Arduino library "ATtinySerialOut". Saves 700 bytes program memory and 70 bytes RAM for ATtinyCore.
#define IR_RECEIVE_PIN  PIN_PB0
#define IR_SEND_PIN     PIN_PB4 // Pin 2 is serial output with ATtinySerialOut. Pin 1 is internal LED and Pin3 is USB+ with pullup on Digispark board.
#define TONE_PIN        PIN_PB3
#define _IR_TIMING_TEST_PIN PIN_PB3
#  elif defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__) // Digispark pro board
#include "ATtinySerialOut.hpp" // Available as Arduino library "ATtinySerialOut"
// For ATtiny167 Pins PB6 and PA3 are usable as interrupt source.
#  if defined(ARDUINO_AVR_DIGISPARKPRO)
// For use with Digispark original core
#define IR_RECEIVE_PIN   9 // PA3 - on Digispark board labeled as pin 9
//#define IR_RECEIVE_PIN  14 // PB6 / INT0 is connected to USB+ on DigisparkPro boards
#define IR_SEND_PIN      8 // PA2 - on Digispark board labeled as pin 8
#define TONE_PIN         5 // PA7 - on Digispark board labeled as pin 5
#define _IR_TIMING_TEST_PIN 10 // PA4
#  else
// For use with ATTinyCore
#define IR_RECEIVE_PIN  PIN_PA3 // On Digispark board labeled as pin 9 - INT0 is connected to USB+ on DigisparkPro boards
#define IR_SEND_PIN     PIN_PA2 // On Digispark board labeled as pin 8
#define TONE_PIN        PIN_PA7 // On Digispark board labeled as pin 5
#  endif
#  elif defined(__AVR_ATtiny84__) // For use with ATTinyCore
#include "ATtinySerialOut.hpp" // Available as Arduino library "ATtinySerialOut". Saves 128 bytes program memory.
#define IR_RECEIVE_PIN   PIN_PB2 // INT0
#define IR_SEND_PIN      PIN_PA4
#define TONE_PIN         PIN_PA3
#define _IR_TIMING_TEST_PIN PIN_PA5
#  elif defined(__AVR_ATtiny88__) // MH-ET Tiny88 board. For use with ATTinyCore.
// Pin 6 is TX, pin 7 is RX
#define IR_RECEIVE_PIN   PIN_PD3 // 3 - INT1
#define IR_SEND_PIN      PIN_PD4 // 4
#define TONE_PIN         PIN_PB1 // 9
#define _IR_TIMING_TEST_PIN PIN_PB0 // 8
#  elif defined(__AVR_ATtiny1616__)  || defined(__AVR_ATtiny3216__) || defined(__AVR_ATtiny3217__) // For use with megaTinyCore
// Tiny Core Dev board
// https://www.tindie.com/products/xkimi/tiny-core-16-dev-board-attiny1616/ - Out of Stock
// https://www.tindie.com/products/xkimi/tiny-core-32-dev-board-attiny3217/ - Out of Stock
#define IR_RECEIVE_PIN   PIN_PA1 // use 18 instead of PIN_PA1 for TinyCore32
#define IR_SEND_PIN      PIN_PA2 // 19
#define TONE_PIN         PIN_PA3 // 20
#define APPLICATION_PIN  PIN_PA0 // 0
#undef LED_BUILTIN               // No LED available on the TinyCore 32 board, take the one on the programming board which is connected to the DAC output
#define LED_BUILTIN      PIN_PA6 // use 2 instead of PIN_PA6 for TinyCore32
#  elif defined(__AVR_ATtiny816__) // For use with megaTinyCore
#define IR_RECEIVE_PIN  PIN_PA1 // 14
#define IR_SEND_PIN     PIN_PA1 // 16
#define TONE_PIN        PIN_PA5 // 1
#define APPLICATION_PIN PIN_PA4 // 0
#undef LED_BUILTIN              // No LED available, take the one which is connected to the DAC output
#define LED_BUILTIN     PIN_PB5 // 4
#  elif defined(__AVR_ATtiny1614__) // For use with megaTinyCore
#define IR_RECEIVE_PIN   PIN_PA1 // 8
#define IR_SEND_PIN      PIN_PA3 // 10
#  elif defined(__AVR_ATtiny1604__) // For use with megaTinyCore
#define IR_RECEIVE_PIN   PIN_PA6 // 2 - To be compatible with interrupt example, pin 2 is chosen here.
#define IR_SEND_PIN      PIN_PA7 // 3
#define APPLICATION_PIN  PIN_PB2 // 5
#define tone(...) void()      // Define as void, since TCB0_INT_vect is also used by tone()
#define noTone(a) void()
#define TONE_PIN         42 // Dummy for examples using it
#  elif defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__) \
|| defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__) \
|| defined(__AVR_ATmega324P__) || defined(__AVR_ATmega324A__) \
|| defined(__AVR_ATmega324PA__) || defined(__AVR_ATmega164A__) \
|| defined(__AVR_ATmega164P__) || defined(__AVR_ATmega32__) \
|| defined(__AVR_ATmega16__) || defined(__AVR_ATmega8535__) \
|| defined(__AVR_ATmega64__) || defined(__AVR_ATmega128__) \
|| defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2561__) \
|| defined(__AVR_ATmega8515__) || defined(__AVR_ATmega162__)
#define IR_RECEIVE_PIN      2
#define IR_SEND_PIN        13
#define TONE_PIN            4
#define APPLICATION_PIN     5
#define ALTERNATIVE_IR_FEEDBACK_LED_PIN 6 // E.g. used for examples which use LED_BUILDIN for example output.
#define _IR_TIMING_TEST_PIN 7
#  else // Default as for ATmega328 like on Uno, Nano, Leonardo, Teensy 2.0 etc.
#define IR_RECEIVE_PIN      2 // To be compatible with interrupt example, pin 2 is chosen here.
#define IR_SEND_PIN         3
#define TONE_PIN            4
#    if defined(ARDUINO_AVR_PROMICRO) // Sparkfun Pro Micro is __AVR_ATmega32U4__ but has different external circuit
// We have no built in LED at pin 13 -> reuse RX LED
#undef LED_BUILTIN
#define LED_BUILTIN         LED_BUILTIN_RX
#    endif
#  endif // defined(__AVR_ATtiny25__)...
#elif defined(ARDUINO_ARCH_RENESAS_UNO) // Uno R4
// To be compatible with Uno R3.
#define TONE_PIN            4
#elif defined(ESP8266)
#define FEEDBACK_LED_IS_ACTIVE_LOW // The LED on my board (D4) is active LOW
#define IR_RECEIVE_PIN          14 // D5
#define IR_SEND_PIN             12 // D6 - D4/pin 2 is internal LED
#define _IR_TIMING_TEST_PIN      2 // D4
#define APPLICATION_PIN         13 // D7
#define tone(...) void()      // tone() inhibits receive timer
#elif defined(CONFIG_IDF_TARGET_ESP32C3) || defined(ARDUINO_ESP32C3_DEV)
#define NO_LED_FEEDBACK_CODE   // The  WS2812 on pin 8 of AI-C3 board crashes if used as receive feedback LED, other I/O pins are working...
#define IR_RECEIVE_PIN           6
#define IR_SEND_PIN              7
#define TONE_PIN                10
#define APPLICATION_PIN         18
#elif defined(ESP32)
#include <Arduino.h>
// tone() is included in ESP32 core since 2.0.2
#if !defined(ESP_ARDUINO_VERSION_VAL)
#define ESP_ARDUINO_VERSION_VAL(major, minor, patch) 12345678
#endif
#if ESP_ARDUINO_VERSION  <= ESP_ARDUINO_VERSION_VAL(2, 0, 2)
#define TONE_LEDC_CHANNEL        1  // Using channel 1 makes tone() independent of receiving timer -> No need to stop receiving timer.
void tone(uint8_t aPinNumber, unsigned int aFrequency){
    ledcAttachPin(aPinNumber, TONE_LEDC_CHANNEL);
    ledcWriteTone(TONE_LEDC_CHANNEL, aFrequency);
void tone(uint8_t aPinNumber, unsigned int aFrequency, unsigned long aDuration){
    delay(aDuration);
    ledcWriteTone(TONE_LEDC_CHANNEL, 0);
void noTone(uint8_t aPinNumber){
#endif // ESP_ARDUINO_VERSION  <= ESP_ARDUINO_VERSION_VAL(2, 0, 2)
#define IR_RECEIVE_PIN          15  // D15
#define IR_SEND_PIN              4  // D4
#define TONE_PIN                27  // D27 25 & 26 are DAC0 and 1
#define APPLICATION_PIN         16  // RX2 pin
#elif defined(ARDUINO_ARCH_STM32) || defined(ARDUINO_ARCH_STM32F1) // BluePill
// Timer 3 blocks PA6, PA7, PB0, PB1 for use by Servo or tone()
#define IR_RECEIVE_PIN          PA6
#define IR_RECEIVE_PIN_STRING   "PA6"
#define IR_SEND_PIN             PA7
#define IR_SEND_PIN_STRING      "PA7"
#define TONE_PIN                PA3
#define _IR_TIMING_TEST_PIN     PA5
#define APPLICATION_PIN         PA2
#define APPLICATION_PIN_STRING  "PA2"
#  if defined(ARDUINO_GENERIC_STM32F103C) || defined(ARDUINO_BLUEPILL_F103C8)
// BluePill LED is active low
#  endif
#elif defined(ARDUINO_ARCH_APOLLO3) // Sparkfun Apollo boards
#define IR_RECEIVE_PIN  11
#define TONE_PIN         5
#elif defined(ARDUINO_ARCH_MBED) && defined(ARDUINO_ARCH_MBED_NANO) // Arduino Nano 33 BLE and Arduino Nano Connect layout for MBED
// Must be before ARDUINO_ARCH_RP2040, since it is the layout for the MBED core of Arduino Nano Connect
#define IR_RECEIVE_PIN      3   // GPIO15 Start with pin 3 since pin 2|GPIO25 is connected to LED on Pi pico
#define IR_SEND_PIN         4   // GPIO16
#define TONE_PIN            5
#define APPLICATION_PIN     6
#define ALTERNATIVE_IR_FEEDBACK_LED_PIN 7 // E.g. used for examples which use LED_BUILDIN for example output.
#define _IR_TIMING_TEST_PIN 8
#elif defined(ARDUINO_ARCH_RP2040) // Arduino Nano Connect, Pi Pico with arduino-pico core https://github.com/earlephilhower/arduino-pico
#define IR_RECEIVE_PIN      15  // GPIO15 to be compatible with the Arduino Nano RP2040 Connect (pin3)
#define IR_SEND_PIN         16  // GPIO16
#define TONE_PIN            17
#define ALTERNATIVE_IR_FEEDBACK_LED_PIN 19 // E.g. used for examples which use LED_BUILDIN for example output.
#define _IR_TIMING_TEST_PIN 20
// If you program the Nano RP2040 Connect with this core, then you must redefine LED_BUILTIN
// and use the external reset with 1 kOhm to ground to enter UF2 mode
#undef LED_BUILTIN
#define LED_BUILTIN          6
#elif defined(PARTICLE) // !!!UNTESTED!!!
#define IR_RECEIVE_PIN      A4
#define IR_SEND_PIN         A5 // Particle supports multiple pins
#define LED_BUILTIN         D7
 * 4 times the same (default) layout for easy adaption in the future
#elif defined(TEENSYDUINO) // Teensy 2.0 is handled at default for ATmega328 like on Uno, Nano, Leonardo etc.
#define TONE_PIN            4
#elif defined(ARDUINO_ARCH_MBED) // Arduino Nano 33 BLE
#define TONE_PIN            4
#elif defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_SAM)
#define TONE_PIN            4
#if !defined(ARDUINO_SAMD_ADAFRUIT) && !defined(ARDUINO_SEEED_XIAO_M0)
// On the Zero and others we switch explicitly to SerialUSB
#define Serial SerialUSB
#endif
// Definitions for the Chinese SAMD21 M0-Mini clone, which has no led connected to D13/PA17.
// Attention!!! D2 and D4 are swapped on these boards!!!
// If you connect the LED, it is on pin 24/PB11. In this case activate the next two lines.
//#undef LED_BUILTIN
//#define LED_BUILTIN 24 // PB11
// As an alternative you can choose pin 25, it is the RX-LED pin (PB03), but active low.In this case activate the next 3 lines.
//#define LED_BUILTIN 25 // PB03
//#define FEEDBACK_LED_IS_ACTIVE_LOW // The RX LED on the M0-Mini is active LOW
#elif defined (NRF51) // BBC micro:bit
#define _IR_TIMING_TEST_PIN 4
#define tone(...) void()    // no tone() available
#else
#warning Board / CPU is not detected using pre-processor symbols -> using default values, which may not fit. Please extend PinDefinitionsAndMore.h.
// Default valued for unidentified boards
#define TONE_PIN            4
#endif // defined(ESP8266)
#if defined(ESP32) || defined(ARDUINO_ARCH_RP2040) || defined(PARTICLE) || defined(ARDUINO_ARCH_MBED)
#define SEND_PWM_BY_TIMER // We do not have pin restrictions for this CPU's, so lets use the hardware PWM for send carrier signal generation
#else
# if defined(SEND_PWM_BY_TIMER)
#undef IR_SEND_PIN // SendPin is determined by timer! This avoids warnings in IRremote.hpp and IRTimer.hpp
#  endif
#endif
#if !defined (FLASHEND)
#define FLASHEND 0xFFFF // Dummy value for platforms where FLASHEND is not defined
#endif
 * Helper macro for getting a macro definition as string
#if !defined(STR_HELPER)
#define STR_HELPER(x) #x
#define STR(x) STR_HELPER(x)
#endif
Really? Is this an IDE 2.x.x bug? I'm going to Preferences now in the new IDE (which I don't love), thanks for the tip.
I've not seen it. I have had autosave off for a while now. I compile unsaved code all the time.
I figure. But you'd be surprised at the number of people who instead of installing the library go and find the one file on github and just download the one file that matches the include without getting the whole repo and then wonder where the rest is.
It was discussed on the forum a few days ago.
where?
I think this was the original, it manifests several ways but always involves 'unsaved'
https://forum.arduino.cc/t/blank-lines-inserted-at-start-of-sketch-causes-library-errors/1283385/31?u=sonofcy
Interesting. I've been compiling unsaved code for a long while now and I've never seen anything like that.
Far out, man. CTRL+Shift+P just opened up a whole new world of possibilities of which I was not aware.
Agreed, many of us have. I suspect the real bug is deeper in the system, and this is just a manifestation.
I've copied the whole piece of code from the simple receive because thats what ive been told to do (im a student) so im not familiar with 100% of it, here it is.
#include <IRremote.hpp> // include the library
    while (!Serial)
        ; // Wait for Serial to become available. Is optimized away for some cores.
    // Just to know which program is running on my Arduino
    Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
    // Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
    IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
    Serial.print(F("Ready to receive IR signals of protocols: "));
    printActiveIRProtocols(&Serial);
    Serial.println(F("at pin " STR(IR_RECEIVE_PIN)));
     * Check if received data is available and if yes, try to decode it.
     * Decoded result is in the IrReceiver.decodedIRData structure.
     * E.g. command is in IrReceiver.decodedIRData.command
     * address is in command is in IrReceiver.decodedIRData.address
     * and up to 32 bit raw data in IrReceiver.decodedIRData.decodedRawData
    if (IrReceiver.decode()) {
         * Print a summary of received data
        if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
            Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
            // We have an unknown protocol here, print extended info
            IrReceiver.printIRResultRawFormatted(&Serial, true);
            IrReceiver.resume(); // Do it here, to preserve raw data for printing with printIRResultRawFormatted()
            IrReceiver.resume(); // Early enable receiving of the next IR frame
            IrReceiver.printIRResultShort(&Serial);
            IrReceiver.printIRSendUsage(&Serial);
         * Finally, check the received data and perform actions according to the received command
        if (IrReceiver.decodedIRData.command == 0x10) {
            // do something
        } else if (IrReceiver.decodedIRData.command == 0x11) {
            // do something else
Do you have a separate tab called PinDefinitionsAndMore.h with this in it?
 * SAMD21       3           4           5
 * ESP32        15          4          27
 * ESP32-C3     6           7          10
 * APOLLO3      11          12          5
#  else
#  endif
#define TONE_PIN            4
#define TONE_PIN            4
#undef LED_BUILTIN
#    endif
#define TONE_PIN            4
#define TONE_PIN                10
#endif
    delay(aDuration);
#  endif
#define TONE_PIN         5
#define TONE_PIN            5
#define TONE_PIN            17
#undef LED_BUILTIN
#define TONE_PIN            4
#define TONE_PIN            4
#define TONE_PIN            4
#endif
#else
#define TONE_PIN            4
#else
#  endif
#endif
#endif
#endif
plus, you have to have this at the top of your sketch if you don't already
Note that this was for an earlier version of the library, not sure what your course instructor was using when s/he wrote the assignment, but I don't know if it's needed with the current version of the library.
Hi @1nks1
Because many common Arduino sketches contain only a single .ino file, it is easy to get the impression that a sketch is only a single file. However, this is not true. The sketch is a folder, which may contain multiple code files. So when you find a sketch on the Internet, you must make sure you get all the files of the sketch.
The "SimpleReceiver" example sketch contains multiple files:
  • SimpleReceiver.ino
  • PinDefinitionsAndMore.h
The cause of the error is that you only took the SimpleReceiver.ino file, but forgot to also grab the PinDefinitionsAndMore.h file of the sketch:
The easiest way to open the full sketch is to simply select File > Examples > IRRemote > SimpleReceiver from the Arduino IDE menus. When you do that, you will see multiple tabs in the Arduino IDE editor, one for each of the files of the sketch. Now compile the sketch. You should now find that the "No such file or directory" error does not occur.
You can modify the example sketch and use File > Save As... to save it to a new sketch. Arduino IDE will save all the files of the sketch to the new sketch.
I have that downloaded off github but I'm not sure what to do with it.
The bug you are referring to is only one rare cause of the common "No such file or directory" error, which only occurs under specific conditions. The much more common cause of this error is that the file simply doesn't exist.
In cases where there are multiple possible causes of a symptom reported by someone requesting support here, it is important to avoid immediately jumping to an arbitrary conclusion about which of the possible causes it is, especially when that arbitrary cause is rare when compared to other potential causes. It is good to form a hypothesis, but if there is insufficient data to prove it then we should follow the scientific method and collect data to either back or disprove the hypothesis before proceeding.
Thank you so much, That worked perfectly and fixed it! I didn't realize you could do that with the IDE.
