I had this posted over in the hardware section and got no response, so I thought I'd try it over here in software. Sorry if you've seen it already.
I am attempting to make an affordable pinewood derby timer for a 4 lane track. I'm using the Arduino Duemilanove controller, a lever switch for the gate, 4 optical sensors to detect the cars, and 4 of the 7 segment serial displays (COM-09230) to display the times.
My plan is to have the system be able to stand alone with the displays, or have a more automated VB front end that will display the times via screen. I will communicate with the displays using NewSoftSerial on the digital pins, leaving the main serial port for programming and hopefully the VB front end.
I have written some test code (see below), to try out the displays. When working properly, it will display 1234 in each display, and when a button is pressed, display only the decimal points.
The problem that I'm having is this. When I have the USB connected, it messes with the displays so that they do not display properly (see pics below). If I disconnect the USB and cycle power, it works fine.
I'd like to have both the displays functional and the USB connection available. I appreciate any help you guys can offer.
Thanks!
Here is a link to my wiring diagram:
http://users.zoominternet.net/~classicmustangefi/Arduino/Main_Circuit%20Rev1.pdf
A pic of my panel.....
Pics of displays working properly......
Pics of displays not working properly.....
#include <NewSoftSerial.h>
int Lane_1Pin = 10;
int Lane_2Pin = 11;
int Lane_3Pin = 12;
int Lane_4Pin = 13;
int Gate_Pin = 9;
int Lane_1_LEDPinTX = 8;
int Lane_2_LEDPinTX = 7;
int Lane_3_LEDPinTX = 6;
int Lane_4_LEDPinTX = 5;
int Lane_1_LEDPinRX = 14;
int Lane_2_LEDPinRX = 15;
int Lane_3_LEDPinRX = 16;
int Lane_4_LEDPinRX = 17;
int test = 0;
NewSoftSerial Lane_1Serial (Lane_1_LEDPinRX, Lane_1_LEDPinTX);
NewSoftSerial Lane_2Serial (Lane_2_LEDPinRX, Lane_2_LEDPinTX);
NewSoftSerial Lane_3Serial (Lane_3_LEDPinRX, Lane_3_LEDPinTX);
NewSoftSerial Lane_4Serial (Lane_4_LEDPinRX, Lane_4_LEDPinTX);
//SoftwareSerial Lane_1Serial (Lane_1_LEDPinRX, Lane_1_LEDPinTX);
//SoftwareSerial Lane_2Serial (Lane_2_LEDPinRX, Lane_2_LEDPinTX);
//SoftwareSerial Lane_3Serial (Lane_3_LEDPinRX, Lane_3_LEDPinTX);
//SoftwareSerial Lane_4Serial (Lane_4_LEDPinRX, Lane_4_LEDPinTX);
// The setup() method runs once, when the sketch starts
// initialize the Lane Signal Pins
pinMode(Lane_1Pin, INPUT);
pinMode(Lane_2Pin, INPUT);
pinMode(Lane_3Pin, INPUT);
pinMode(Lane_4Pin, INPUT);
pinMode(Gate_Pin, INPUT);
// Turn on Pull Up Resistor on Gate Input
digitalWrite(Gate_Pin,HIGH);
//Initialize the LED Serial Pins
pinMode(Lane_1_LEDPinTX, OUTPUT);
pinMode(Lane_2_LEDPinTX, OUTPUT);
pinMode(Lane_3_LEDPinTX, OUTPUT);
pinMode(Lane_4_LEDPinTX, OUTPUT);
pinMode(Lane_1_LEDPinRX, INPUT);
pinMode(Lane_2_LEDPinRX, INPUT);
pinMode(Lane_3_LEDPinRX, INPUT);
pinMode(Lane_4_LEDPinRX, INPUT);
Lane_1Serial.begin(9600);
Lane_2Serial.begin(9600);
Lane_3Serial.begin(9600);
Lane_4Serial.begin(9600);
// the loop() method runs over and over again,
// as long as the Arduino has power
int delaytime = 0;
int OneShotOn = 0;
int OneShotOff = 0;
test = digitalRead(Gate_Pin);
if ((test == 1) && (OneShotOn == 0)){
Lane_1Serial.print(1);
delay(delaytime);
Lane_1Serial.print(2);
delay(delaytime);
Lane_1Serial.print(3);
delay(delaytime);
Lane_1Serial.print(4);
delay(delaytime);
Lane_2Serial.print(0x01,BYTE);
delay(delaytime);
Lane_2Serial.print(0x02,BYTE);
delay(delaytime);
Lane_2Serial.print(0x03,BYTE);
delay(delaytime);
Lane_2Serial.print(0x04,BYTE);
delay(delaytime);
Lane_3Serial.print(0x01,BYTE);
delay(delaytime);
Lane_3Serial.print(0x02,BYTE);
delay(delaytime);
Lane_3Serial.print(0x03,BYTE);
delay(delaytime);
Lane_3Serial.print(0x04,BYTE);
delay(delaytime);
Lane_4Serial.print(0x01,BYTE);
delay(delaytime);
Lane_4Serial.print(0x02,BYTE);
delay(delaytime);
Lane_4Serial.print(0x03,BYTE);
delay(delaytime);
Lane_4Serial.print(0x04,BYTE);
delay(delaytime);
OneShotOn = 1;
OneShotOff = 0;
else if ((test == 0) && (OneShotOff == 0)){
/*Lane_1Serial.print(0x78,BYTE);
Lane_2Serial.print(0x78,BYTE);
Lane_3Serial.print(0x78,BYTE);
Lane_4Serial.print(0x78,BYTE);
Lane_4Serial.print(0x78,BYTE);*/
Lane_1Serial.print(0x77,BYTE);
Lane_1Serial.print(0x01,BYTE);
Lane_2Serial.print(0x77,BYTE);
Lane_3Serial.print(0x77,BYTE);
Lane_4Serial.print(0x77,BYTE);
OneShotOff = 1;
OneShotOn = 0;
