I use ethernet2 shield. It work perfectly (with ethernet2 library).
i want to work on discover routine for my arduino's network (server on arduino mega and clients on arduino uno r3), and i have tested icmp-ping library.
Icmp-pin library seems to work only with ethernet library.
hi,
Your answer is precise and concise, but i have some difficult to understand ... what about "No link, though." ???
ICMP-ping library work with ethernet library and not ethernet2 library, so i can't use it ...
i am searching a solution to implement a network discover based on ping, and the only solution i have found is based on icmp-ping library
You have some hardware. We need to know specifically what hardware you have. The easiest way to tell is that is to provide a URL, using the link icon (the infinity symbol with the green blob below it).
You are using some libraries. We need to know specifically what libraries you have. The easiest way to tell is that is to provide a URL, using the link icon (the infinity symbol with the green blob below it).
I don't think that, technically, there is any reason why the ethernet2 library can not deal with ping requests. But, we need to know which ethernet2 library you are using in order to understand why it can't.
i'm not a specialist on C language, but in icmg-ping.h, we find two library (Eternet.h and utility/w5100.h) : so it's not a solution for my problem (ethernet shield V2 is based on wiznet5500 composant ...)
Perhaps you haven't discovered that arduino.org and arduino.cc are NOT the same place. You are having problems with arduino.org products and libraries. The place to ask for help with their stuff is not here.
