Ping prox
hello all
i have and uno with a parallax ping and a few leds.
my goal is to have the led light when object is within a certain range
my question is this
how to i make the output of the ping trigger and led
heres a sample of the code so far...again this is public code not my own.....yet :)
/* Ping))) Sensor
This sketch reads a PING))) ultrasonic rangefinder and returns the distance to the closest object in range. To do this, it sends a pulse to the sensor to initiate a reading, then listens for a pulse to return. The length of the returning pulse is proportional to the distance of the object from the sensor.
The circuit: * +V connection of the PING))) attached to +5V * GND connection of the PING))) attached to ground * SIG connection of the PING))) attached to digital pin 7
http://www.arduino.cc/en/Tutorial/Ping
created 3 Nov 2008 by David A. Mellis modified 30 Jun 2009 by Tom Igoe
This example code is in the public domain.
// this constant won't change. It's the pin number // of the sensor's output: const int pingPin = 7;
void setup() { // initialize serial communication: Serial.begin(9600); }
void loop() { // establish variables for duration of the ping, // and the distance result in inches and centimeters: long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW);
// The same pin is used to read the signal from the PING))): a HIGH // pulse whose duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH);
// convert the time into a distance inches = microsecondsToInches(duration); cm = microsecondsToCentimeters(duration);
Serial.print(inches); Serial.print("in, "); Serial.print(cm); Serial.print("cm"); Serial.println();
delay(100); }
long microsecondsToInches(long microseconds) { // According to Parallax's datasheet for the PING))), there are // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per // second). This gives the distance travelled by the ping, outbound // and return, so we divide by 2 to get the distance of the obstacle. // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf return microseconds / 74 / 2; }
long microsecondsToCentimeters(long microseconds) { // The speed of sound is 340 m/s or 29 microseconds per centimeter. // The ping travels out and back, so to find the distance of the // object we take half of the distance travelled. return microseconds / 29 / 2; }
So, what is the problem? Does the serial output match the distance from the sensor to the object it is sensing, within reasonable levels of accuracy?
Have you looked at the documentation here: http://arduino.cc/en/Reference/HomePage
A simple if statement and a call to digitalWrite() are all that you need.
modified code what am i doing wrong?
// this constant won't change. It's the pin number // of the sensor's output: int pingPin = 7; int led = 13;
void setup() { // initialize serial communication: Serial.begin(9600); pinMode(led, OUTPUT); }
delay(100); }
dist = digitalRead(pingPin); if (dist == 10) { // turn LED on: digitalWrite(led, HIGH); } else { // turn LED off: digitalWrite(led, LOW); } }
errors Ping:88: error: expected constructor, destructor, or type conversion before '=' token Ping:89: error: expected unqualified-id before 'if' Ping:93: error: expected unqualified-id before 'else' Ping:97: error: expected declaration before '}' token
This code is outside of any function -should it be in "loop"?
   if (dist == 10) {
    // turn LED on:
  else {
    // turn LED off:
(please use the # icon on the toolbar when posting code)
