Ping/RFID Reader not working.
I wrote some code for the TouchShield and Arduino to make a basic GUI that I’m calling pArduOS. For some reason, the RFID reader (Parallax) and the Ping)) won’t report their data to the computer.
Code follows:
TouchShield Code
  background(0,0,0);
  stroke(255);
  text("pArduOS, Version .1",205,2);
  text("Written by Adam Aitoumeziane",150,10);
  text("Includes code samples from arduino.cc",95,18);
  fill(0,0,255);
  rect(0,0,50,50);
  text("Ping",12,22);
  fill(0,255,0);
  rect(0,75,50,50);
  text("RFID",12,97);
  gettouch();
  if(mouseX > 0 & mouseX < 50 & mouseY > 0 & mouseY < 50) {
    Serial.print('A');
  if(mouseX > 0 & mouseX < 50 & mouseY > 75 & mouseY < 125) {
    Serial.print('B');
Arduino Code
#include <AFSoftSerial.h>
#define RXPIN 3
#define TXPIN 2
int pingPin = 7;
char myChar;
int  val = 0;
char code[10];
int bytesread = 0;
AFSoftSerial tss = AFSoftSerial(RXPIN,TXPIN);
  tss.begin(9600);
  Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(4,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(4, LOW);                  // Activate the RFID reader
  if(Serial.available() > 0) {
    myChar = tss.read();
  if(myChar == 'A') {
    pingProg();
  if(myChar == 'B') {
    rfidProg();
int pingProg() {
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // We give a short LOW pulse beforehand to ensure a clean HIGH pulse.
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
int rfidProg() {
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
      bytesread = 0;
      delay(500);                       // wait for a second
  long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
Nevermind!
I fixed the error.
This is what the problem was:
It should say:
  if(tss.available() > 0) {
