ping sensor reading 0
Hey I've got a robot with a ping sensor mounted on front. I want it to go forward till it sees a wall the turn and keep going. But it goes forward sees a wall then goes in circles because the sensor keeps reading 0. How do I solve this can I reset the sensor using arduino?
const int leftMotor = 10;
const int rightMotor = 9;
const int pingPin = 7;
const int ledPin = 12;
  pinMode(rightMotor, OUTPUT);
  pinMode(leftMotor, OUTPUT);
  pinMode(ledPin, OUTPUT);
  long duration, inches, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches); //for testing purposes
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  if(inches<4 ) { //I want it to turn when it see something less than 4 inches
    digitalWrite(ledPin, HIGH);
    digitalWrite(leftMotor, LOW);
    digitalWrite (rightMotor, LOW);
    digitalWrite(leftMotor, HIGH);
    delay(300);
    digitalWrite(ledPin, LOW);
    if(inches<4) { //once it turns i want it to read agian then do a 180
      digitalWrite(ledPin, HIGH); // if inches is less than 4
      digitalWrite(rightMotor, LOW);
      delay(600);
  else {
    digitalWrite(rightMotor, HIGH);
long microsecondsToInches(long microseconds)
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
  long  cm;
  Serial.print(cm);
  Serial.print("cm");
Why is any of this code here? You don't care about the distance in centimeters.
Then there is something wrong with your sensor, or how it is connected to the Arduino.
Is this a cross-post?
http://arduino.cc/forum/index.php/topic,109896
Thread locked.
