This is the code for a robot car with a ping sensor that I'm doing for a school project.
It's won't compile and I don't understand why the error messages it's showing are doing so, can someone help me?
#include <NewPing.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
#include <Servo.h>
#define TRIGGER_PIN 12
#define ECHO_PIN 11
#define MAX_DISTANCE 200
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
Servo myservo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
int leftsonar;
int rightsonar;
int centersonar;
int forwardsonar;
int spintimer;
int sensvalues[5];
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Adafruit Motorshield v2 - DC Motor test!");
AFMS.begin();
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(90);
myMotor->setSpeed(150);
myOtherMotor->setSpeed(150);
myMotor->run(FORWARD);
myOtherMotor->run(BACKWARD);
myMotor->run(RELEASE);
myOtherMotor->run(RELEASE);
void loop(){
createandsortarray();
forwardsonar = sensvalues[3];
if (forward == 0 || forwardsonar >=15) {
forward();
else{
dontmove();
lookaround();
uint8_t i;
void forward(){
myOtherMotor->run(FORWARD);
for (i=0; i<255; i++) {
myMotor->setSpeed(i);
myOtherMotor->setSpeed(i);
running = true
void backup(){
myMotor->run(BACKWARD);
running = true
void dontmove(){
myMotor->setSpeed(0);
myOtherMotor->setSpeed(0);
running = false;
void turnright(){
void turnleft(){
void lookaround(){
pingservo.write(180);//right
rightsonar = sensvalues[3];
pingservo.write(0);//left
leftsonar = sensvalues[3];;
pingservo.write(90); //middle
centersonar = sensvalues[3];
if (leftsonar == 0 && rightsonar == 0)
spin();
else{
if (leftsonar > rightsonar){
turnleft();
else if (rightsonar > leftsonar){
turnright();
else if (rightsonar <= 10 && leftsonar <= 10 && centersonar <= 10){
backup();
lookaround();
else if (centersonar >= 15 || centersonar == 0){
forward();}
void createandsortarray(){
int i = 0;
while (i <5){
sensvalues = sonar.ping_cm();
- i++;*
- sort(sensvalues, 5);*
void sort(int a[], int size) { - for(int i=0; i<(size-1); i++) {*
- for(int o=0; o<(size-(i+1)); o++) {*
- if(a[o] > a[o+1]) {*
- int t = a[o];*
- a[o] = a[o+1];*
- a[o+1] = t;*
Error Messages:
Arduino: 1.6.6 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Michael Gomez\Downloads\MG_Final_Project_Code\MG_Final_Project_Code.ino: In function 'void loop()':
MG_Final_Project_Code:41: error: 'createandsortarray' was not declared in this scope - createandsortarray();*
MG_Final_Project_Code:47: error: 'dontmove' was not declared in this scope - dontmove();*
MG_Final_Project_Code:48: error: 'lookaround' was not declared in this scope - lookaround();*
C:\Users\Michael Gomez\Downloads\MG_Final_Project_Code\MG_Final_Project_Code.ino: In function 'void forward()':
MG_Final_Project_Code:60: error: 'running' was not declared in this scope - running = true*
MG_Final_Project_Code:62: error: expected ';' before 'void'
void backup(){
MG_Final_Project_Code:144: error: expected '}' at end of input - }*
exit status 1
'createandsortarray' was not declared in this scope - This report would have more information with*
- "Show verbose output during compilation"*
- enabled in File > Preferences.*
