system
January 9, 2014, 10:19pm
1
what is wrong with this?
#define pingPin 7
#define led 13
#define led2 12
#define led3 11
#define led4 10
#define led5 9
#define led6 8
#define buzzer 3
int sound = 250;
Serial.begin (9600);
pinMode(pingPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(buzzer, OUTPUT);
long duration, distance;
duration = pulseIn(pingPin, HIGH);
distance = (duration/2) / 26.1;
if (distance <= 27) {
digitalWrite(led, HIGH);
sound = 250;
else {
digitalWrite(led,LOW);
if (distance < 22) {
digitalWrite(led2, HIGH);
sound = 260;
else {
digitalWrite(led2, LOW);
if (distance < 18) {
digitalWrite(led3, HIGH);
sound = 270;
else {
digitalWrite(led3, LOW);
if (distance < 13) {
digitalWrite(led4, HIGH);
sound = 280;
else {
digitalWrite(led4,LOW);
if (distance < 8) {
digitalWrite(led5, HIGH);
sound = 290;
else {
digitalWrite(led5,LOW);
if (distance < 3) {
digitalWrite(led6, HIGH);
sound = 300;
else {
digitalWrite(led6,LOW);
if (distance > 27 || distance <= 0){
Serial.println("Out of range");
noTone(buzzer);
else {
Serial.print(distance);
Serial.println(" cm");
tone(buzzer, sound);
You never send a trigger pulse to start a range acquisition.
system
January 9, 2014, 10:36pm
3
better?
#define pingPin 7
#define led 13
#define led2 12
#define led3 11
#define led4 10
#define led5 9
#define led6 8
#define buzzer 3
int sound = 250;
distance = (duration/2) / 29.1;
sound = 250;
else {
sound = 260;
else {
sound = 270;
else {
sound = 280;
else {
if (distance < 8) {
sound = 290;
else {
if (distance < 3) {
sound = 300;
else {
noTone(buzzer);
else {
Which sensor do you have? Is it 3 pins or 4 pins? In either case you must trigger the sensor with a digital output, then use pulseIn on a digital input to get the duration till echo is detected. The is a library for the Ping sensor (3 pins) and numerous examples if a 4 pin HC-SR04,
Then use the Ping library http://playground.arduino.cc/Code/Ping . They handle the trigger and echo signals on the same pin. You set the pingPin to OUTPUT with pinMode, send a trigger (if memory serves a HIGH pulse), set the pingPin to INPUT again using pinMode then call the pulseIn function to measure duration.
system
January 9, 2014, 11:22pm
7
i just started this a few weeks ago so i probably sound stupid but where would it go on the script?
The main part is like:
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH); // HIGH pulse to trigger sensor
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
The tutorial can explain it much better than I can. If you have questions after reading the tutorial i will be glad to try and answer them.
system
January 10, 2014, 1:49am
9
ok so i got the ping))) working but all of my LEDs are lit up? what is my mistake?
#include <Ping.h>
Ping ping = Ping(3,74,29);
#define pingPin 7
#define led 13
#define led2 12
#define led3 11
#define led4 10
#define led5 9
#define led6 8
#define buzzer 3
int sound = 250;
void setup(){
void loop(){
ping.fire();
Serial.print("Microseconds: ");
Serial.print(ping.microseconds());
Serial.print(" | Inches ");
Serial.print(ping.inches());
Serial.print(" | Centimeters: ");
Serial.print(ping.centimeters());
sound = 250;
else {
sound = 260;
else {
sound = 270;
else {
sound = 280;
else {
if (distance < 8) {
sound = 290;
else {
if (distance < 3) {
sound = 300;
else {
noTone(buzzer);
else {
