ping transmitter and receiver
hi everyone.
in my project I need to build a ping ultrasonic transmitter and use another ping sensor to receive that signal,to test that method I removed the emitter from one of the pings and the receive from the other one,and I modified the arduino ping example sketch to test it,so one of pings will send the signal and the other one receive it . but that didn't work ,what kind of method should I use
here is the code
const int pingPin1 = 7;
const int pingPin2 = 8;
  long duration, inches, cm;
  pinMode(pingPin1, OUTPUT);
  digitalWrite(pingPin1, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin1, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin2, INPUT);
  duration = pulseIn(pingPin2, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
long microsecondsToInches(long microseconds)
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
But what did it do?
My guess is the receiver didn't listen, because it didn't get a trigger pulse to transmit.
Please use code tags when posting code.
AWOL:
But what did it do?
yes ,by using the serial monitor it shows that it didn't read the ultrasonic signal(it shows 0cm,0inch),and I am using the same arduino uno for both pings
I am sorry but I don't know how to use the code tags
So, trigger the receiver when you trigger the transmitter.
It is explained here, at the top of this section, in bold
AWOL:
sorry to bother you again sir but I am still a beginner in using the arduino and sensors in general,so how can I trigger them both at the same time
You're triggering one now, so all you need to do is insert the same sequence of pinMode and digitalWrite for the second sensor pin.
You can go back and edit previous posts by clicking on "Modify", then add the code tags, then click on "save".
