Ping phones and tablets of friends in your network with an arduino with ethernet shield, when a phone or tablet is detected send a pushover message to your own android or iOS phone or tablet.
This way when friends visit you, you know who is visiting you or who visited you when you where not at home.
The idea is to receive a message before they even ring the doorbell because they are detected on your wifi network.
All you need to do is give these friends a static ip address in your router from their phones/tablets mac address.
If your friends get new phones, you never have to change the code, just assign the new mac address of their new phone in your router.
PingMaster project by M.J. Meijer 2014
Ping phones/tablets of friends in your network, when a phone/tablet is found => send a pushovermessage to your own phone/tablet
This way you know who is visiting you when they make contact to you wifi network
Also usefull to see if friends visited you while you where not at home
You need to give friends a static ip address on your router from the mac address of their phones/tablets
Parts needed:
-Arduino Uno http://www.dx.com/p/uno-r3-atmega328p-uno-r3-development-board-deep-blue-285620
-Ethernet Shield: http://www.dx.com/p/ethernet-shield-with-wiznet-w5100-ethernet-chip-tf-slot-118061
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // mac addres for ethernet shield
byte ip[] = {192,168,2,177}; // ip address for ethernet shield
// Pushover settings
char pushoversite[] = "api.pushover.net";
char apitoken[] = "your30characterapitokenhere123";
char userkey [] = "your30characteruserkeygoeshere";
int length;
// Static IP of phones from friends
IPAddress Friend1(192,168,2,200);
IPAddress Friend2(192,168,2,201);
IPAddress Friend3(192,168,2,202);
IPAddress Friend4(192,168,2,203);
IPAddress Friend5(192,168,2,204);
// Set variables
boolean friend1po = false;
boolean friend2po = false;
boolean friend3po = false;
boolean friend4po = false;
boolean friend5po = false;
int pingfailed1 = 0;
int pingfailed2 = 0;
int pingfailed3 = 0;
int pingfailed4 = 0;
int pingfailed5 = 0;
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
EthernetClient client;
/********** Setup **********/
// start Ethernet
Ethernet.begin(mac, ip);
//Serial.begin(9600);
delay(2500);
pushover("The PingMaster server started");
/********** Loop **********/
pingfriends();
/********** Ping telefoons van bekenden **********/
void pingfriends()
ICMPEchoReply echoReply1 = ping(Friend1, 4);
if (echoReply1.status == SUCCESS)
if (friend1po == false)
pushover("Phone from Friend1 detected");
friend1po = true;
else if (echoReply1.status != SUCCESS)
pingfailed1++;
if (pingfailed1 > 500)
friend1po = false;
pingfailed1 = 0;
ICMPEchoReply echoReply2 = ping(Friend2, 4);
if (echoReply2.status == SUCCESS)
if (friend2po == false)
pushover("Phone from Friend2 detected");
friend2po = true;
else if (echoReply2.status != SUCCESS)
pingfailed2++;
friend2po = false;
pingfailed2 = 0;
ICMPEchoReply echoReply3 = ping(Friend3, 4);
if (echoReply3.status == SUCCESS)
if (friend3po == false)
pushover("Phone from Friend3 detected");
friend3po = true;
else if (echoReply3.status != SUCCESS)
pingfailed3++;
if (pingfailed3 > 500)
friend3po = false;
pingfailed3 = 0;
ICMPEchoReply echoReply4 = ping(Friend4, 4);
if (echoReply4.status == SUCCESS)
if (friend4po == false)
pushover("Phone from Friend4 detected");
friend4po = true;
else if (echoReply4.status != SUCCESS)
pingfailed4++;
if (pingfailed4 > 500)
friend4po = false;
pingfailed4 = 0;
ICMPEchoReply echoReply5 = ping(Friend5, 4);
if (echoReply5.status == SUCCESS)
if (friend5po == false)
pushover("Phone from Friend5 detected");
friend5po = true;
else if (echoReply5.status != SUCCESS)
pingfailed5++;
if (pingfailed5 > 500)
friend5po = false;
pingfailed5 = 0;
/********** Send pushover message **********/
byte pushover(char *pushovermessage)
String message = pushovermessage;
length = 81 + data.length();
if(client.connect(pushoversite,80))
client.println("POST /1/messages.json HTTP/1.1");
client.println("Host: api.pushover.net");
client.println("Connection: close\r\nContent-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.print(length);
client.println("\r\n");;
client.print("token=");
client.print(apitoken);
client.print("&user=");
client.print(userkey);
client.print("&message=");
client.print(message);
client.stop();
enjoy!
