Hello.
A question about the library GxEPD2 from Author ZinggJM.
I use a Waveshare e-paper 2.13inch HAT (B) experimentally with an Arduino Nano.
In the GxEPD2 library I select the right 3color display.
The problem or the blemish that i have is a pinkish frame around the edge of the display.
(i would like to add a photo, but i'm afraid of being banished again)
If i use the library from the manufactor Waveshare the pinkish frame disappear.
But i want to use the GxEPD2 library, there is a lot advantages.
Does anyone know how to prevent the pinkish frame?
Thank you for pointing me to this issue. The display driver code for most panels is derived from demo code from Good Display. And some of the code is already quite old. The Waveshare code may be newer.
Maybe it is just the selection of the border waveform that is different. You could take a look at the display initialization code. Or hope and wait for an improvement in a later version of GxEPD2 (not the one that is pending to be released), if I remember your post.
The change makes no difference on my display. It has the same narrow light pink border in both cases, also around the round connection dot. I don't know if this is the border that should be controllable by some bits of this command.
Please report if this has the desired effect on your display.
