My robot arm needs 4 pins for each encoder. Is there a way to set pinMode for multiple inputs at once?
Or do I have to do them all individually?
Thanks,John
Example
pinMode (2,3,4,5, INPUT_PULLUP);
Thanks,John
Example
No. Put them in an array and loop through it.
Do you have an example on how to do that?
not tested
const byte inPutPins[] = {2,3,4,5,6};
#define NUM sizeof(inPutPins) / sizeof(inPutPins[0])
for ( byte x = 0; x < NUM; x++ ) {
pinMode(inPutPins[x],INPUT_PULLUP);
since they're bytes
You can use a for/next loop
Along the lines of …
for ( x=3; x<6 ; x++)
pinMode (x,OUTPUT);
Which arduino?
What is "next loop" in C/C++?
not tested
//pinMode (2,3,4,5, INPUT_PULLUP);
DDRD &= B11000011;
PORTD |= B01111100;
What makes you think OP is using an Arduino board with an AVR processor?
It’s a description of the function that explains what it does it’s not code and certainly different to a previous loop
Great AVR hack. I love uber efficient AVR code, but it's not portable and unless a uS or two at startup is important, portability is probably better.
