PinMode setup question
Hello,
Can I set pinMode as Input or Output according to an EEPROM value?
Like that?
#include <EEPROM.h>
byte value=0;
  value = EEPROM.read(0);
  if (value==0)
    pinMode(3,INPUT_PULLUP);
    pinMode(3,OUTPUT);
(Sketch compiles)
Thank you
Pete
Yes
If you are feeling brave (or foolish) you can even do
    pinMode(3,EEPROM.read(0));
as long as the EEPROM contains the appropriate value
INPUT = 0
OUTPUT = 1
INPUT_PULLUP = 2
But be aware that there are some changed afoot to do with the values that prevent this working
Perfect, thank you very much! I like your shortcut as well but because of the reason you said, I'll stick with the if statement and the commands instead of numbers.
I am not sure why you want to read the required pinMode() from EEPROM but if you need to you can change the pinMode() on the fly anywhere in the program
