The ATmega2560 uses serial communication for getting uploaded sketches and communication with the Arduino IDE Serial Monitor (e.g. Serial.prinln()) but most computers these days don't have a true serial port. Nowadays we use USB to connect devices to our computers. The ATmega2560 is a very nice microcontroller but it doesn't have any USB capabilities. For this reason a separate chip is usually added to Arduino boards that acts as a bridge between the serial communication of the ATmega2560 and the USB of your computer. The computer then creates a virtual COM port that makes it seem like your board is connected to a serial port on your computer even though it's connected via USB. The ATmega16U2 is a microcontroller that has native USB capabilities so it can be programmed to act as a serial-USB bridge.
Other Arduino boards use chips that are specifically designed for this use. The most common are the FTDI FT232 (AKA "FTDI") and the CH340.
Typically the only reason you will need to think about this chip is if you need to install the correct drivers for it in order for your board to be recognized by your computer. The Arduino IDE comes with the drivers for the ATmega16U2 and FT232 so usually you will only have troubles with that if you get one of the clone Arduino boards that use the CH340 (that's the cheapest of the three chips so it's quite common on the cheap clones).
There are some Arduino boards that use microcontrollers with native USB capabilities. These boards do not require a separate bridge chip, they can communicate directly over USB. The most common are the Arduino Leonardo and the Pro Micro.
