Pins 9-13 wont work with LEDs
Hello! Today i was playing around with my arduino and i had 8 LEDs from pin 2 to pin 8 i found some more wire and LEDs of the same exact kind and now when i try to use pins 9-13 it measures 0.3 mA when active and 0.2 mA when not active on the multimeter. I know the LEDs are not the problem because i switched the 1st LED with the last and it worked fine. Can anyone help?
Here is my pictures: My Files and here is my code: http://pastebin.com/cB8kLJrL
Thanks, Seth
orbitwar:
The owner of this folder has not added any files.
orbitwar:
...now when i try to use pins 9-13 it measures 0.3 mA when active and 0.2 mA when not active on the multimeter.
Forgot to call pinMode, eh?
It works now! Thanks for the help. I just started programming arduino about 2 weeks ago and im still bad...
Thanks, Seth
