Pins floating after reset?
I suspect that the pins are floating after a reset. I wrote this code for checking
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
digitalWrite(11, 0);
digitalWrite(12, 0);
and connected my digilent analog discovery to gnd, di0-PIN12, di1-pin11.
The attached picture shows the result. The time seems to be the same for pin 13 to come on.
Is there any way to prevent this?
No, that is how it is, and that is how it should be.
If you want a pin to stay low during reset, use a pulldown resistor.
Or a pullup if you want them high, say for keeping a High Side switch (PNP, P-channel MOSFT) turned off.
Why... why are those pins pulsing in that attached image? It looks like they ought to be static. Were you resetting it during that time, and are objecting to the delay between the reset, and the signal being reasserted? In that case, use a pulldown/pullup resistor as suggested above. You could reduce the length of that delay after the end of reset if you programmed it via ISP instead of normal serial, and removed the bootloader (the bootloader runs right after reset, and waits a very short time to see if you're trying to program it). But that makes reprogramming it considerably less pleasant.
Or is your problem that the board was resetting at all during that time?
I believe the pins seem to be pulsating because they are high impedance so the analyzer picks up any kind of disturbance.
My problem was that i wanted to do some timing analysis on interrupts but the false triggering made that very difficult. I found some 10k sils lying around, that solved the problem.
Nice fix :)
nilton61: I believe the pins seem to be pulsating because they are high impedance so the analyzer picks up any kind of disturbance.
To be precise 50Hz mains frequency if you measure the traces!
