In the "official" tutorial for the I2S microphone, e.g. https://www.arduino.cc/en/Tutorial/ArduinoSoundSpectrumSerialPlotter I found in the code example this snippet
Circuit:
* Arduino/Genuino Zero, MKRZero or MKR1000 board
* ICS43432:
* GND connected GND
* 3.3V connected 3.3V (Zero) or VCC (MKR1000, MKRZero)
* WS connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero)
* CLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero)
* SD connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero)
So I would assume that I have to use e.g. for the WS (Word Select / Frame Select) pin 0 for the "normal" Arduino Zero and pin 3 for the MKR1000 and MKRZero.
But have a look at the corresponding Fritzing wiring on top of the same page:
It's the MKRx board but wiring is:
- WS -> pin 2
- CLK -> pin 1
- SD -> pin A5
So what is correct? The information in the Fritzing schema or the comment in the code?
