pins for PCB to plug into DIP socket
Hi, Is there a correct header or pin type to use if I want to make a PCB circuit which serves as a direct plug-in replacement for a DIP device? For example, to remove a 28 pin DIP chip from its socket and plug in a small PCB in its place? One row may be surface mount and the other row through hole. Thanks.
Normal 0.1" pin header has wider diameter pins - in some sockets, it will simply not fit, while in others, it will damage the socket so normal IC's don't fit anymore.
What you need is called "machined pin header" - it can be had from china for next to nothing, just like normal pin header.
Excellent, thanks!
http://www.dipmicro.com/store/HDR40X1MM One side is smaller diameter than the other for plugging into sockets.
I will check that out, thanks. I have a weirduino project in mind for these.
