Pins going high momentarily on switch on.
I have made my first project using a Due with lots of leds being controlled by a handful of switches . It works fine but I'm having a problem with the fact that quite a few of the leds flash very briefly when the power to the arduino is switched on , and I am using the power that runs to some of the leds to also trigger relays . Since I don't want these relays triggered until the leds in question are switched on by the switches via the arduino , it's a problem. All the leds are switched on by conditional switches , "if" in the code , so as far as I can see there is no reason for them to light up due to the sketch running.
If it is a natural part of the functioning of the arduino that they should briefly blink when the arduino is first powered on , is there any way I can prevent it happening?
A schematic (photo of hand drawn is fine) would be useful. Your code will also be helpful.
There is a known issue with the DUE, it does not have an effective power on reset.
It might be related to your problem.
Yes.
When ever a processor is reset all pins default to inputs, and these inputs can float high, in effect turning on any sensitive output.
The cure is normally to fit a pull down resistor, or to wire the outputs so they are a current sink rather than a current source. This of course inverts the output logic but that is easy enough to change in software.
