Pins not changing
First Arduino question ever… I normally program in JS and C#, some of my terminology here may reflect that and I’d like to apologize upfront.
I’m writing an environment controller using an Mega2560, a DHT22 and an array of relays and Potentiometers outputting to a 16X2 LCD.
I’m trying to read two pots, one represents the low temp and the represents the high. I wanna kick a relay on or off for heating an cooling. If/when the pot is adjusted or the temp range falls or rises I want the relay to open or close accordingly. Sounded simple enough. However, the state of the relay doesn’t seem to change.
Attached is my code file.
I think I’m doing it right. The pinModes are in the setup routine. Using timers instead of delays, and my serial output looks like this if I adjust the pots.
This should be cooling
Temp Heat Event
62/68 49/60
T: 69.4 H: 43.3
Avg T:65Avg H:54
This should be heating
Temp Heat Event
52/59 49/60
T: 69.4 H: 43.2
Avg T:55Avg H:54
I think I’m missing something simple
HumidityThaw.ino (12.6 KB)
coderbond:
How do you know?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks... Tom... :slight_smile:
@Coding Badly
The serial message doesn’t change, the LED doesn’t change and neither does the relay.
If I uncomment the bootSequence method in the startup routine it runs thru and activates and deactivates each relay/led pair as expected.
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#include <dht_nonblocking.h>
#define DHT_SENSOR_TYPE DHT_TYPE_22
static const int DHT_SENSOR_PIN = 2;
DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
int humHighSettingPin = A12; //Humidity High
int humHighValue = 0;
int humLowSettingPin = A13; //Humidity Low
int humLowValue = 0;
int tempHighSettingPin = A14; //TempHigh
int tempHighValue = 0;
int tempLowSettingPin = A15;  //TempLow
int tempLowValue = 0;
int medianTemp = 0;
int medianHumdity = 0;
float temperaturePin;
float temperatureValue;
float humidityPin;
float humidityValue;
    // set up the LCD's number of columns and rows:
lcd.init();
lcd.backlight();
pinMode(23, OUTPUT); //Unknown
pinMode(24, OUTPUT); //Unknown
pinMode(25, OUTPUT); //Unknown
pinMode(26, OUTPUT); //Unknown
pinMode(27, OUTPUT); //Unknown
pinMode(28, OUTPUT); //Unknown
pinMode(29, OUTPUT); //Unknown
pinMode(30, OUTPUT); //Unknown
pinMode(31, OUTPUT); //Unknown
pinMode(32, OUTPUT); //Unknown
pinMode(33, OUTPUT); //Unknown
pinMode(34, OUTPUT); //Unknown
pinMode(35, OUTPUT); //Unknown
pinMode(36, OUTPUT); //Unknown
pinMode(37, OUTPUT); //Unknown
//bootSequence();
unsigned long previousMillis = 0;
long interval = 1000;   //Humidifier Cold Cycle Length
int ledState = LOW;             // ledState used to set the LED
long lcdScrollInterval = 750;
  unsigned long currentMillis = millis(); //Get the current cycle
  //This is checking an event if you will....
  //In this case the measure environment. which is using a DHT22.
  //Note: the DHT22 is limited to one read every 4 seconds.
  //This is the theoretical maximum of the machine+
  if( measure_environment( &temperaturePin, &humidityPin ) == true )
    temperatureValue = temperaturePin;
    humidityValue = humidityPin;
  if (measure_pots(&tempLowSettingPin) == true)
    tempLowValue = map(analogRead(tempLowSettingPin), 0, 1023, 20, 90);
    tempHighValue = map(analogRead(tempHighSettingPin), 0, 1023, 25, 98);
    humLowValue = map(analogRead(humLowSettingPin), 0 , 1023, 10, 90);
    humHighValue = map(analogRead(humHighSettingPin), 0, 1023, 10, 90);
    medianTemp = ((tempLowValue + tempHighValue) / 2);
    medianHumdity = ((humLowValue + humHighValue) / 2);
  if (measure_updateDisplay() == true)
    //displayRunMode(temperatureValue, tempLowValue, tempHighValue, humidityValue, humLowValue, humHighValue);
    displayRunMode(temperatureValue, tempLowValue,tempHighValue,humidityValue, humLowValue,humHighValue);
    serialDisplay(temperatureValue, tempLowValue, tempHighValue, humidityValue, humLowValue, humHighValue, ((tempLowValue + tempHighValue) / 2), ((humLowValue + humHighValue) / 2));
      if (temperatureValue > medianTemp)
        Serial.print("Temp Cool Event");
        Serial.print("\n");
        digitalWrite(30, HIGH);        //Cool pin on
        digitalWrite(33, HIGH);       //LED Indicator
        digitalWrite(28, LOW);
        digitalWrite(31, LOW);
      else if (temperatureValue < medianTemp)
        Serial.print("Temp Heat Event");
        Serial.print("\n");
        digitalWrite(28, HIGH);
        digitalWrite(31, HIGH);
        digitalWrite(30, LOW);
        digitalWrite(33, LOW);
      }else
        Serial.print("Temp Rest Event");
        Serial.print("\n");
 * Poll for a measurement, keeping the state machine alive.  Returns
 * true if a measurement is available.
 //This defines an event based on a Timer if you will...
 //It's referenced in the main Loop event
static bool measure_environment( float *temperature, float *humidity )
  static unsigned long measurement_timestamp = millis( );
  /* Measure once every four seconds. */
  if( millis( ) - measurement_timestamp > 3000ul )
    if( dht_sensor.measure( temperature, humidity ) == true )
      return( true );
  return( false );
static bool measure_pots(int *tempLow){
      if( millis( ) - measurement_timestamp > 300ul )
      return( true );
  return( false );
static bool measure_updateDisplay()
    static unsigned long measurement_timestamp = millis();
  if (millis() - measurement_timestamp > 300ul)
    return(true);
  return(false);
void bootSequence()
  //// Device Boot Test
lcd.print("Enviro Con 1.0");
lcd.clear();
lcd.print("Test Power On");
delay(2000);
lcd.clear();
//Dehumidify Defrost
//TURN ON THE OTHER HUM LIGHT
lcd.setCursor(0,0);
lcd.print("Pin 23 Open");
lcd.setCursor(0,1);
lcd.print("Dehum circuit open");
  digitalWrite(23, HIGH);
delay(4000);
  digitalWrite(23, LOW); //dehum circuit on
lcd.clear();
//Dehumidify Run -- Running
lcd.setCursor(0,0);
lcd.println("Pin 25 Open");
lcd.setCursor(0, 1);
lcd.println("Dehumidify (+)");
  digitalWrite(23, HIGH); //dehum circuit on
  digitalWrite(24, HIGH); //dehum light on
  digitalWrite(25, HIGH); //dehum pos voltage
delay(4000);
  digitalWrite(23, LOW); //dehum circuit off
  digitalWrite(24, LOW); //dehum light off
  digitalWrite(25, LOW); //defum negative voltage
lcd.clear();
//Dehum Run -- Defrost Cycle
lcd.setCursor(0,0);
lcd.println("Pin 27 Open");
lcd.setCursor(0,1);
lcd.println("Dehumidify (-)");
  digitalWrite(26, HIGH); //hum light on
  digitalWrite(27, HIGH); //dehum neg voltage off
delay(4000);
  digitalWrite(26, LOW); //hum light off
  digitalWrite(27, LOW); //dehum neg voltage off
lcd.clear();
//Humdifier on
lcd.setCursor(0,0);
lcd.println("Pin 29 Open");
lcd.setCursor(0,1);
lcd.println("Humidier Run");
  digitalWrite(26, HIGH); //hum light off
  digitalWrite(29, HIGH); //humdifier circuit on
delay(4000);
  digitalWrite(29, LOW); //humifier curcuit off
lcd.clear();
//Heat Run
lcd.setCursor(0,0);
lcd.println("Pin 31 Open");
lcd.setCursor(0,1);
lcd.println("Heat Run");
delay(4000);
lcd.clear();
//Cool Run
lcd.setCursor(0,0);
lcd.println("Pin 33 Open");
lcd.setCursor(0,1);
lcd.println("Cool Run");
delay(4000);
lcd.clear();
//Logs output to serial display for debug purposes
void serialDisplay(float _temp, int _tempLow, int _tempHigh, float _humidity, int _humidityLow, int _humidityHigh, int _medianTemp, int _medianHumidity){
      Serial.print(_tempLow);
      Serial.print("/");
      Serial.print(_tempHigh);
      Serial.print("  ");
      Serial.print(_humidityLow);
      Serial.print("/");
      Serial.print(_humidityHigh);
      Serial.print( "\n" );
      Serial.print("T: ");
      Serial.print(((_temp * 9/5) + 32), 1);
      Serial.print("    H: ");
      Serial.print( _humidity, 1 );
      Serial.print("Avg T:");
      Serial.print(_medianTemp);
      Serial.print("Avg H:");
      Serial.print(_medianHumidity);
Not 100% sure (can't verify now).
measurement_timestamp is set to millis(). Immediately after that you check millis() minus measurement_timestamp; chances that the difference between the two is zero are about 100%.
sterretje:
Not 100% sure (can’t verify now).
*measurement_timestamp* is set to millis(). Immediately after that you check millis() minus measurement_timestamp; chances that the difference between the two is zero are about 100%.
Note that ‘measurement_timestamp’ is ‘static’ so it only gets initialized are startup time. It is not like a local variable that gets initialized each time through the function. That piece of code should work as expected.
This is working as expected. From what I read it was a basic pattern for using timers vs delays…
But I think I may have found my problem…
This is displaying the value as fahrenheit and the pots scaled to a farenheit range.
      }else
but the conditional statement is using the raw values from the DHT22 which are celsius. I’ll report back when I get home and test this theory.
