Pins supporting Int Change mode?
Can you clarify which pins on Arduino 101 support Interrupt type CHANGE?
The following is from the Arduino 101 tech spec:
External Interrupts on all pins. Can trigger an interrupt on a low value, high value, a rising or falling edge, or a change in value (change is only supported by pins 2, 5, 7, 8, 10, 11, 12, 13).
I was able to get interrupts on both edges of Pin 2, but only on either the falling or rising, but not both for pin 5.
Pending confirmation, but that '5' looks like a typo. It is my understanding that pins with PWM functionality (3,5,6,9) and Analog functionality (A0 - A5) cannot support CHANGE.
All others can. :-)
Thanks for the info. Based on this, I moved the interrupt from pin 5 to pin 4, and was able to confirm interrupts were happening on both edges in the CHANGE mode on pin 4.
So it sounds like the spec should be CHANGE mode interrupts are supported only on pins 2, 4, 7, 8, 10, 11, 12, 13.
This was a life saver; I spent hours trying to figure this one out. Any chance we can get this actually updated in the documentation??
