Arduino: 1.8.9 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Balaji\AppData\Local\Arduino15\packages -hardware C:\Users\Balaji\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Balaji\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Balaji\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10809 -build-path C:\Users\Balaji\AppData\Local\Temp\arduino_build_342761 -warnings=none -build-cache C:\Users\Balaji\AppData\Local\Temp\arduino_cache_963083 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\Balaji\Documents\Arduino\bb\bb.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Balaji\AppData\Local\Arduino15\packages -hardware C:\Users\Balaji\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Balaji\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Balaji\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10809 -build-path C:\Users\Balaji\AppData\Local\Temp\arduino_build_342761 -warnings=none -build-cache C:\Users\Balaji\AppData\Local\Temp\arduino_cache_963083 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\Balaji\Documents\Arduino\bb\bb.ino
Using board 'uno' from platform in folder: C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2
Using core 'arduino' from platform in folder: C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2
Detecting libraries used...
"C:\\Users\\Balaji\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Balaji\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\Balaji\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "C:\\Users\\Balaji\\AppData\\Local\\Temp\\arduino_build_342761\\sketch\\bb.ino.cpp" -o nul
In file included from C:\Users\Balaji\AppData\Local\Temp\arduino_build_342761\sketch\bb.ino.cpp:1:0:
C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/Arduino.h:258:10: fatal error: pins_arduino.h: No such file or directory
#include "pins_arduino.h"
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
I am getting this error when i upload example blink code to my Arduino UNO R3
There is "C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino\pin_arduino.h"
this pins_arduino.h in my File as well as arduino library file
"C:\Users\Balaji\Documents\Arduino\libraries\NotePad\pin_arduino.h"
Please why this error occurs
Help me learn Arduino UNO R3
Did you mean #include <pins_arduino.h>
@balaji123456
This had nothing to do with the section you posted in.
Moved your topic to it's current location / section as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
TheMemberFormerlyKnownAsAWOL:
Yes,
In file included from C:\Users\Balaji\AppData\Local\Temp\arduino_build_740803\sketch\Blink.ino.cpp:1:0:
exit status 1
I got the above error message...
The Blink code is not even compiling or verifying
The blink example sketch is as follows.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
Are you saying your blink sketch is different ?
The output from the blink sketch compile has no reference to the file you are saying.
ScreenShot
Yes Sir,
I Opened the code from
File -> Examples -> 01.Basic -> Blink
I also tried using Online Arduino Web Editor (Using Create Agent Plugin), it works fine.
But when i Use Arduino IDE (Offline) this error occurs
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Balaji\AppData\Local\Arduino15\packages -hardware C:\Users\Balaji\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Balaji\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Balaji\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\Balaji\AppData\Local\Temp\arduino_build_694874 -warnings=all -build-cache C:\Users\Balaji\AppData\Local\Temp\arduino_cache_728571 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Balaji\AppData\Local\Arduino15\packages -hardware C:\Users\Balaji\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Balaji\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Balaji\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\Balaji\AppData\Local\Temp\arduino_build_694874 -warnings=all -build-cache C:\Users\Balaji\AppData\Local\Temp\arduino_cache_728571 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Balaji\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
"C:\\Users\\Balaji\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Balaji\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\cores\\arduino" "-IC:\\Users\\Balaji\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.2\\variants\\standard" "C:\\Users\\Balaji\\AppData\\Local\\Temp\\arduino_build_694874\\sketch\\Blink.ino.cpp" -o nul
Alternatives for pins_arduino.h: []
ResolveLibrary(pins_arduino.h)
-> candidates: []
In file included from C:\Users\Balaji\AppData\Local\Temp\arduino_build_694874\sketch\Blink.ino.cpp:1:0:
exit status 1
The Code I am using is as follows
Blink
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
