'PinStatus' does not name a type
In file included from C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WiFi\src/WiFiStorage.h:23,
from C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WiFi\src/WiFi.h:38,
from C:\Users\Lenovo\Documents\Arduino\esssp\esssp.ino:2:
C:\Users\Lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WiFi\src/utility/wifi_drv.h:293:12: error: 'PinStatus' does not name a type
static PinStatus digitalRead(uint8_t pin);
exit status 1
Compilation error: exit status 1
I have updated Arduino SAMD Boards (32-bits ARM Cortex-M0+) but it still does not work
That line, wherever it is in your code, is nonsense. I don't know what you intended for it to do, but it is complete nonsense.
Since you didn't post any of your code I will assume that you don't want any help fixing the problem.
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
// or another board which has PSRAM enabled
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_ESP_EYE
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
const char* ssid = "***";
const char
password = "*****";
#define LED_BUILTIN 4
#define relay 4
#define buzzer 2
boolean matchFace = false;
boolean activeRelay = false;
long prevMillis = 0;
int interval = 5000;
void startCameraServer();
Serial.setDebugOutput(true);
pinMode(relay, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode (LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(relay, LOW);
digitalWrite(buzzer, LOW);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
//initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1);//flip it back
s->set_brightness(s, 1);//up the blightness just a bit
s->set_saturation(s, -2);//lower the saturation
//drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
if (matchFace == true && activeRelay == false){
activeRelay = true;
digitalWrite (relay, HIGH);
digitalWrite (buzzer, HIGH);
delay(800);
digitalWrite (buzzer, LOW);
prevMillis = millis();
if(activeRelay == true && millis()- prevMillis > interval){
matchFace = false;
its in the library or something i dont know whats wrong
why do you have WiFiNINA files copied into esp32 WiFi library and what has the SAMD core to do with this?
@UMm
Please apply autoformatting to the code (Ctrl-T in IDE) and insert it to the forum again, using the code tags this time.
It will help you to understand that many parts of the code are outside any functions and procedures, what is illegal for C/C++ language. In general, the code looks like a mess of unconnected pieces, it is not a surprise that the code is not compile.
I saw this post
That post is about a completely different type of board. Are you using the MKR Wifi 1010 or an ESP32?
ESP32 board
Please return and edit your post, inserting the code using code tags.
