PIR activated SMS alert
HI guys!
I'm using SIM900 , an arduino mega 2560, and a PIR sensor. I want my arduino to send SMS alerts everytime the PIR sensor detects motion. I already know how to send SMS, and I already knew how PIR sensor works with my mega2560. However I dont know how they work together.
this is the code for sending SMS and it works fine:
#include <SoftwareSerial.h>
SoftwareSerial SIM900(0, 1);
SIM900.begin(19200);
SIM900power();
delay(20000); // give time to log on to network.
void SIM900power()
// software equivalent of pressing the GSM shield "power" button
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(5000);
void sendSMS()
SIM900.print("AT+CMGF=1\r"); // AT command to send SMS message
SIM900.println("AT + CMGS = "+639368266683""); // recipient's mobile number, in international format
SIM900.println("Hello, world. This is a text message from an Arduino Mega 2560."); // message to send
SIM900.println((char)26); // End AT command with a ^Z, ASCII code 26
SIM900.println();
delay(5000); // give module time to send SMS
SIM900power(); // turn off module
sendSMS();
do {} while (1);
while this is the code for testing my PIR sensor:
  • PIR sensor tester
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
Instead of
put in a call to sendSMS()
how can I combine the two?
Copy all your definitions, etc, and put the contents of setup() into one, copy all your routines into the sketch and use the loop() from the PIR sketch instead of the SMS one. Then change the line as I suggested. There are several posts and articles explaining how to combine two sketches, do a search if you need a more detailed explanation.
And don't put SoftwareSerial on pins 0 & 1.
Hello
I have the operating mist because they do not fully understand what write.
Thanks.
Hi.
