Hello. I' doing a project involving the use of sensors and one of the sensors I am using is the PIR motion sensor.
I used this code from https://raw.github.com/jedgarpark/Make_PIR_Sensor/master/MAKE_PIR_Sensor.pde
// Uses a PIR sensor to detect movement, buzzes a buzzer
// more info here: http://blog.makezine.com/projects/pir-sensor-arduino-alarm/
// based upon:
// PIR sensor tester by Limor Fried of Adafruit
// tone code by michael@thegrebs.com
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int pinSpeaker = 10; //Set up a speaker on a PWM pin (digital 9, 10, or 11)
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
pinMode(pinSpeaker, OUTPUT);
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
playTone(300, 160);
delay(150);
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
playTone(0, 0);
delay(300);
if (pirState == HIGH){
// we have just turned off
Serial.println("Motion ended!");
pirState = LOW;
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq) {
duration *= 1000;
int period = (1.0 / freq) * 1000000;
long elapsed_time = 0;
while (elapsed_time < duration) {
digitalWrite(pinSpeaker,HIGH);
delayMicroseconds(period / 2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
I had to modify it since I'm not using a LED.
void loop(){
playTone(300, 160);
delay(150);
pirState = HIGH;
playTone(0, 0);
delay(300);
pirState = LOW;
duration *= 1000;
When I uploaded the code, the buzzer buzzed a certain number of times and would stop and start again, but the sensor wasn't detecting anything moving. I'm not sure what else to do next since I followed the schematic.
I used this tutorial: PIR Sensor Arduino Alarm | Make:
Thank you for all the help.
