I have a PIR Motion Sensor for an Arduino Duemilanove 328 from Cool Components .co.uk.
It is connected using 3V3 to B+, ground to GND and Alarm to 220 ohm resistor to Digital In 2.
The code on the board is:
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
void loop(){
Serial.println(val);
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
The code compiles and uploads correctly but regardless of motion the input constantly reads LOW.
Can anyone suggest where I'm going wrong?
Thanks,
Chris
