PIR Input programming
Ok, I have a PIR and some code which work together fine.
At the moment if motion is continuous the LED brightens from 0-255, then jumps back to 0 and climbs to 255 again (as expected) if motion is continuous.
I would like the output (LED) to remain at (255 = brightest) until no motion is detected for x number of subsequent digitalReads of the input.
How to implement this?
Thanks a bunch.
int LED = 11;
int sensor = 7;
int n = 0;
int light = 0;
void setup(){
  pinMode(LED, OUTPUT);
  pinMode(sensor, INPUT);
  digitalWrite(LED, LOW);
void loop(){
  int sens = digitalRead(sensor);
  if(sens == LOW)
    for(n=0; n<255; n++)
      analogWrite(LED, n);
      delay(10);
      Serial.println(n);
    light = 1;
  if (light == 1)
    if (sens == HIGH)
      for(n=255; n>-1; n--)
        delay(10);
        Serial.println(n);
      light = 0;
Incomplete requirements are nearly impossible to implement.
You need to look at the state change detection example, to learn how to detect a change from no motion to motion, or from motion to no motion.
Do something when each transition occurs.
Step 1: write your code using "pseudocode" - i.e., plain english.
If movement and brightness is less than 255
  increase brightness
end if
if no movement and brightness is not 0
  set brightness to 0
end if
Then convert that to real code - should be simple enough...
majenko:
increase brightness
end if
  set brightness to 0
end if
Really appreciate the pointers majenko. Thanks.
