PIR L298 motor control
Newbie. I want the PIR sensor to turn the motor on three seconds. I've edited the sketch every which way but the right way. Would appreciate help. Thank you.
  pinMode(2, INPUT);  // pir
  pinMode(3, OUTPUT); // enable pin
  pinMode(4, OUTPUT); // output1
  pinMode(5, OUTPUT); // output2
  digitalWrite(3, HIGH); // enabling
  digitalWrite(2, LOW); // putting PIR into LOW
  digitalWrite(4, LOW); // default pin HIGH
  digitalWrite(5, LOW);
  delay(1500); //calibration time for pir
  if (digitalRead(2) == HIGH){
    digitalWrite(5, HIGH);
    delay(15000);
  else{
  delay(1500);
what circuit are you using to control the motor?
doesn't the enable pin need to be set HIGH and the pins 4 and 5 set oppositely to control direction?
You forgot to say what the code is doing now, if anything.
If it does nothing, take the if/else out and see if the motor switches on then off. That will tell you if the L298N and motor are wired and powered correctly.
Steve
