Hi everyone,
I have this PIR motion sensor: PIR (motion) sensor : ID 189 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits. It works great when powered and connected to an Arduino board, like in this circuit:
The thing I want to accomplish is actually the other way around: having the PIR sensor powered by a power source (batteries for example) and the Arduino powered by the output of the PIR sensor. As a result, the Arduino will power on when movement is detected and shut down when there is no movement. It's basically like this circuit, just replace the LED with an Arduino board:
The reason I'm trying to accomplish this is that I can run the PIR sensor on batteries for a long time, it uses around 65uA when idle. The Arduino should take care of sending a signal (wireless) to a receiver when booted. This combination should allow me to have a wireless motion sensor running for a long time on batteries.
The issue I'm facing is that it seems the output of the PIR sensor (3.3V when high) is not sufficient to power the Arduino (I have a board that's capable of running on 3.3V). Is there a way to only power the Arduino when motion is detected? Would a transistor work?
Many thanks!!
Jan
