Bonjour j'aurais besoin de votre aide.
Je souhaiterai commander un relais via un PIR.
Je dispose de ce code:
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 30;
// The time the device will stay on
int delayTime = 5000;
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int relayPin = 3;
int pirState = LOW; // we start, assuming no motion detected
int stateRelay = HIGH;
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(relayPin, OUTPUT);
pinMode(inputPin, INPUT); // declare sensor as input
digitalWrite(relayPin, stateRelay);
//give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for(int i = 0; i < calibrationTime; i++){
Serial.print(".");
Serial.println("SENSOR ACTIVE");
delay(50);
void loop(){
val = digitalRead(inputPin); // read input value
//Serial.println(val);
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
delay(150);
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
delay(300);
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
Serial.println(pirState);
if(pirState == HIGH){
digitalWrite(relayPin, LOW);
delay(delayTime);
digitalWrite(relayPin, HIGH);
Le problème c'est que je souhaite que le relais s'éteigne une fois que je repasse ma main devant le PIR.
Est ce possible ?
Merci de votre aide.
Tom
