PIR - Relay problem
This sketch will turn the LED on and off with motion detected, but when the relay is included, the sketch is repetitive; flashing the LED and tripping the relay regardless of PIR input. Any idea what I am doing wrong?
int calibrationTime = 30;
[code]int calibrationTime = 30;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 1500; //5000
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 8;    //the digital pin connected to the PIR sensor's output
int ledPin = 13;
int relayPin = 2;
//SETUP
void setup(){
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(relayPin,OUTPUT);
  digitalWrite(pirPin, LOW);
  digitalWrite(relayPin,LOW);
//LOOP
void loop(){
  if(digitalRead(pirPin) == HIGH){
    digitalWrite(ledPin,LOW);
    //the led visualizes the sensors output pin state
    if(lockLow){
      //makes sure we wait for a transition to LOW before any further output is made:
      lockLow = false;
      Serial.println("---");
      Serial.print("motion detected at ");
      Serial.print(millis()/50);//1000
      Serial.println(" sec");
      delay(50);
    takeLowTime = true;
  if(digitalRead(pirPin) == LOW){
    digitalWrite(ledPin, HIGH);
    digitalWrite(relayPin,HIGH);
    delay(5000);
    digitalWrite(ledPin, LOW);
    if(takeLowTime){
      lowIn = millis();          //save the time of the transition from high to LOW
      takeLowTime = false;       //make sure this is only done at the start of a LOW phase
    //if the sensor is low for more than the given pause,
    //we assume that no more motion is going to happen
    if(!lockLow && millis() - lowIn > pause){
      //makes sure this block of code is only executed again after
      //a new motion sequence has been detected
      lockLow = true;
      delay(50);
[/code]
Schematic?
