Hello Folks,
I am trying to get this working but no matter what i try its not what i want. hopesome one could point me in te good direction.
What i want:
I press pincode on Keypad. When pincode is correct we wait for input from pir sensor.
If pir sensor pin is High a buzzer will go on.
If the Pir sensor is high for 10 seconds i want my relay to switch on. And in the mean time the buzzer is stil on.
When pir is triggert i have 10 seconds to turn alarm off by enter Off pincode.
My problem is that while counting down to 10 seconds i can not control keypad. So i can not deactivate the alarm.
My Code is very messy with loads of test and copy paste. So dont laugh please.
I hope soembody can give me a pointer in the right direction.
#include <Keypad.h>
#define Password_Length 5
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 1500;
boolean alarmState;
boolean lockLow = true;
boolean takeLowTime;
boolean Counter = false;
boolean Start = false;
char Data[Password_Length];
char Master[Password_Length] = "12A3";
char MasterUit[Password_Length] = "12B3";
int powerPin = 4;
int SolarPin = 12;
int pirSensorPin = 5; // Pir sensor input signaal
int pirState = LOW; // Start zonder beweging detectie
int val = 0;
byte data_count = 0;
char customKey;
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {11,10,9,8};
byte colPins[COLS] = {7,6,3,2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
int Tijd = 10;
int calibrationTime = 10;
pinMode(pirSensorPin,INPUT);
pinMode(powerPin,OUTPUT);
pinMode(SolarPin,OUTPUT);
digitalWrite(powerPin, LOW);
alarmState = false;
if (alarmState == true) {
alarmIn();
KeyUit();
else {
Key();
void clearData() {
// Go through array and clear data
while (data_count != 0) {
Data[data_count--] = 0;
return;
void alarmIn() {
val = digitalRead(pirSensorPin);
if(val == HIGH){
//digitalWrite(SolarPin, HIGH);
if(lockLow){
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
Serial.println(Tijd);
Start = true;
takeLowTime = true;
Timer();
Relay();
if(digitalRead(pirSensorPin) == LOW){
digitalWrite(powerPin, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
Serial.print(Tijd);
digitalWrite(SolarPin, LOW);
delay(10);
Tijd=10;
Start = false;
// --- Alarm aan
void Key() {
pinMode(pirSensorPin, INPUT);
// Wacht op keypad invoer
customKey = customKeypad.getKey();
if (customKey) {
// Enter keypress into array and increment counter
Data[data_count] = customKey;
Serial.print(Data[data_count]);
delay(100);
data_count++;
// lengte paswoord
if (data_count == Password_Length - 1) {
//// Alarm Aan
if (!strcmp(Data, Master)) {
// Password is correct
Serial.print("OK!");
for(int i = 0; i < calibrationTime; i++){
Serial.print(".");
delay(200);
Serial.println("Sensor active");
alarmState = true;
Timer();
// Foute code
else {
// Password is incorrect
Serial.print("FOUT!");
delay(200);
// Clear data
clearData();
// --- Alarm off
void KeyUit() {
if (customKey) {
delay(100);
data_count++;
if (!strcmp(Data, MasterUit)) {
pinMode(pirSensorPin, OUTPUT);
Serial.println("Alarm Uit");
delay(100);
delay(100);
delay(100);
alarmState = false;
else {
Serial.print("Error!");
delay(200);
clearData();
void alarm(long duration, int freq) {
tone(SolarPin, freq);
delay(duration);
noTone(SolarPin);
void Timer(){
if (val == HIGH) {
Tijd--;
void Relay() {
if (Start = true && Tijd==0) {
digitalWrite(powerPin, HIGH);
