PIR sensor and relay
I have a small problem with PIR sensor. I want to control relay (which will control solenoid, but that's not important) with PIR sensor (HC-SR505). The problem is, when the sensor is first activated relay turns on and off in infinite loop. Please help. There is my code:
#define pir_sensor 3
#define solenoid 2
int on_time = 1500;
bool detected = false;
void m_detector() {
  detected = true;
  pinMode(pir_sensor, INPUT_PULLUP);   //PIR sensor
  pinMode(solenoid, OUTPUT);           //Water output
  attachInterrupt(digitalPinToInterrupt(3), m_detector, RISING);
  delay(2000);    //Power up delay
  Serial.println(detected);
  if (detected == true) {
    digitalWrite(solenoid, HIGH);
    delay(on_time);
    digitalWrite(solenoid, LOW);
    detected = false;
