PIR sensor: how to connect
Hi, I'm getting started with Arduino...and in these days I'm reading the data sheets of the things that I bought and that will arrive to me in the ext days.
I have a problem, i bought a Pir sensor (http://www.watterott.com/en/PIR-Motion-Sensor) and this is the datasheet:http:
But,reading some manuals on Arduino, I have understood that it can't give to the sensor the 12V that it would, so I have to do a particular circuit.
I understand that the particular circuit should have some components, and I have these:
-Diode 1n4007
-MOS Irf540
-BC 547 Transistor
In general I have all the components of this kit:
http://www.watterott.com/download/workshop_kit.pdf
HOw can I let work my PIR Sensor???
I don't know if my English is clear....Thank you...!!!
I would try getting it working first without the 12v circuit.
I would try the jumper cable to 3.3 volts.
The website states:
This unit works great from 5 to 12V (datasheet shows 12V). You can also install a jumper wire past the 5V regulator on board to make this unit work at 3.3V. Sensor uses 1.6mA@3.3V.
You say tha t maybe it can work at 5V that means at 3.3 V ...It's exact???
Thank you!!!
