PIR Sensor Issue
My sensor is not working properly.
I have 5V connected to VCC, GND connected to GND, and Out connected to 13.
this is my code -
int inputPin = 13; // choose the input pin (for PIR sensor) int pirState = LOW; // we start, assuming no motion detected int val = 0; // variable for reading the pin status
void setup() { pinMode(inputPin, INPUT); // declare sensor as input
Serial.begin(9600); }
void loop(){ val = digitalRead(inputPin); // read input value if (pirState == LOW) { // we have just turned on Serial.println("Motion detected!"); // We only want to print on the output change, not state pirState = HIGH; }
if (pirState == HIGH){ // we have just turned of Serial.println("Motion ended!"); // We only want to print on the output change, not state pirState = LOW; } }
I'm just getting an infinite loop even if the sensor isn't connected. What am I doing wrong?
I don't see you actually use that value.
Maybe you mean this..
if (val == HIGH && pirState == LOW) {
Leo..
Gr1m: My sensor is not working properly.
this is my code -
Hi Gr1m,
May I take a look at your sensor's pic?
