Hi
My project is sending data wirelessly from using the PIR sensor as the INPUT and made the LED light on another side as OUTPUT and it is two ways communication. So I tried to edit the code from this site which using a button as INPUT but it still doesn't work.
Any suggestion or topic that I should read.
Appreciate your help.
// First Arduino
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte addresses [][6] = {"00001", "00002"}; //Setting the two addresses. One for transmitting and one for receiving
int pir_pinA = 5;
int led_pinA = 13;
boolean valA = 0;
boolean valB = 0;
pinMode(pir_pinA, INPUT);
pinMode(led_pinA, OUTPUT);
radio.begin(); //Starting the radio communication
radio.openWritingPipe(addresses[1]); //Setting the address at which we will send the data
radio.openReadingPipe(1, addresses[0]); //Setting the address at which we will receive the data
radio.setPALevel(RF24_PA_MIN); //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
radio.stopListening(); //This sets the module as transmitter
valA = digitalRead(pir_pinA);
radio.write(&valA, sizeof(valA)); //Sending the data
delay(5);
radio.startListening(); //This sets the module as receiver
while(!radio.available()); //Looking for incoming data
radio.read(&valB, sizeof(valB)); //Reading the data
if (valB == LOW)
digitalWrite(led_pinA, HIGH);
digitalWrite(led_pinA, LOW);
//Second Arduino
#include <SPI.h>
#include <RF24.h>
const byte addresses [][6] = {"00002", "00001"}; //Setting the two addresses. One for transmitting and one for receiving
int pir_pinB = 5;
int led_pinB = 13;
boolean valA = 0;
boolean valB = 0;
pinMode(pir_pinB, INPUT);
pinMode(led_pinB, OUTPUT);
radio.read(&valA, sizeof(valA));
if(valA == LOW)
digitalWrite(led_pinB, HIGH);
digitalWrite(led_pinB, LOW);
delay(5);
radio.write(&valB, sizeof(valB)); //Sending the data
