PIR sensor reads HIGH even with no motion
The PIR sensor stayed as HIGH as soon as I uploaded the code into the arduino board. May I ask is there something wrong with my code?
The circuit diagram looks like this:
Here is the code:
int LED = 13;             // the pin that the LED is atteched to
int PIR = 2;              // the pin that the sensor is atteched to
  pinMode(LED, OUTPUT);   // initalize LED as an output
  pinMode(PIR, INPUT);    // initialize sensor as an input
  Serial.begin(9600);     // initialize serial
void loop(){
  if (digitalRead(PIR == HIGH)) { // check if the sensor is HIGH
    digitalWrite(LED, HIGH);      // turn LED ON
    Serial.println("Motion detected!");
    delay(100);                   // delay 100 milliseconds
  else {
    digitalWrite(LED, LOW);       // turn LED OFF
    Serial.println("Motion stopped!");
Check the PIR sensor for adjustment potentiometers for sensitivity and time on.
Also check the ground connection to the PIR which does not appear clearly on your image.
Post a link to a product page describing your sensor.
The connection to the sensor looks incorrect for HC-SR501, but who knows which one you are using
ground does not seem connected to the breadboard rail.. only to the LED..
Oops
Hi, @gwynethchiew
Can you post a link to the PIR please?
Is its output open collector?
If so then change.
To;
pinMode(PIR, INPUT_PULLUP);    // initialize sensor as an input
It will turn on the internal pull up resistor in the UNO so a circuit exist for collector current.
Tom.... :smiley: :+1: :coffee: :australia:
thank you so much, it worked
Thanks to everyone for helping me, i have found the solution :+1:
