Howdy,
I have a PIR sensor and simply want to have a green LED light up when there's motion detected, otherwise have a red LED light up. I have that part working, no problemo. However, it seems that when I move my hand in front of the sensor, and then move it away, the PIR still thinks the motion is there for a slight delay (a second maybe). Is there a way to get rid of this delay, so it will only light the green LED while something is moving?
Or, is it more of a matter of buying a higher quality PIR sensor?
Here's my code, FYI:
int IRpin = 2; // choose the input pin (for PIR sensor)
int greenLed = 4; // choose the green LED
int redLed = 3; // choose the red LED
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
// initialize the digital pin as an output.
pinMode(greenLed, OUTPUT);
pinMode(redLed, OUTPUT);
pinMode(IRpin, INPUT);
void GreenOn(){
digitalWrite(greenLed, HIGH); // turn the green LED on (HIGH is the voltage level)
// delay(250); // wait for a second
// digitalWrite(greenLed, LOW); // turn the green LED off by making the voltage LOW
void GreenOff () {
void RedOn() {
digitalWrite(redLed, HIGH); // turn the green LED on (HIGH is the voltage level)
// digitalWrite(redLed, LOW); // turn the green LED off by making the voltage LOW
void RedOff() {
// the loop routine runs over and over again forever:
val = digitalRead(IRpin); //read the input value from the IR sensor
if (val == HIGH) { //check if the input is HIGH (i.e. detects motion)
RedOff();
GreenOn();
else { // if there's no movement, blink RED
GreenOff();
RedOn();
Thanks for any help/ideas!
