PIR sensor triggering on something other than movement
I have a robotic arm (2DOF) which I activate based on the PIR sensor movement detection. The nano has the following connections:
Pin 6 - PIR Data
Pin 7 - Servo 1 Signal
Pin 8 - Servo 2 Signal
Pin 5V - VCC on Servo1, Servo2 && PIR
Pin GND- GND on Servo1,Servo3&&PIR
Its starts out fine, buteven if no movement it triggers after a few seconds, then it stops, but after a few more seconds it triggers again and so on. Triggering even gets faster after a while. Im powering the nano through a usb cable to a 5v/2A plug. I guess the servos are interfering or something with the nano, but Im not sure what or how to fix it. I even moved the attach() command out from setup to only upon triggering and added a detach() as well, to avoid the servos from drawing that quirky power they draw while attached but still.
Here is the code:
#include <Servo.h>
int pirPin = 6;
int state = LOW;
int val = 0;
Servo leftElbowServo;
Servo leftPincerServo;
  pinMode (pirPin, INPUT);
  val = digitalRead(pirPin);   // read sensor value
  if (val == HIGH) {           // check if the sensor is HIGH
    digitalWrite(13, HIGH);   // turn LED ON
    delay(1000);                // delay 100 milliseconds
    Serial.println("motion...attach and run");
    if (state == LOW) {
      attachServos();
      state = HIGH;       // update variable state to HIGH
      startRoutine();
  } else if (val == LOW){ //if val=LOW
    digitalWrite(13, LOW); // turn LED OFF
    delay(2000);             // delay 200 milliseconds
    Serial.println("all is quiet");
    detachServos();
    if (state == HIGH){
      state = LOW;       // update variable state to LOW
void attachServos() {
   //  Setup Servos
   //Servo1 - Left elbow
   leftElbowServo.attach(7);
   //Servo2 - Left Pincer
   leftPincerServo.attach(8);
   zeroOut();
void detachServos() {
  zeroOut();
  leftElbowServo.detach();
  leftPincerServo.detach();
void startRoutine() {
  //zeroOut();
  //delay(1000);
  liftLeft();
  openLeft();
  lowerLeft();
  closeLeft();
void zeroOut(){
  leftElbowServo.write(10);
  leftPincerServo.write(10);
void liftLeft(){
    leftElbowServo.write(150);
void lowerLeft(){
    leftElbowServo.write(40);
void openLeft(){
    leftPincerServo.write(150);
void closeLeft(){
    leftPincerServo.write(40);
Marciokoko:
I think that's a reasonable guess. To confirm, write a basic sketch that only reads the PIR and outputs the result to the LED or Serial Monitor. Then run that without the servos attached to your Arduino board. If the problem still occurs, you'll know that the servos are not the problem.
What servos?
Are you sure your power supply can handle their rated power 2-3 times over (stall current), especially if routed through your Arduino board?
PIR detectors are sensitive to tiny changes in voltage from the sensors, which means without a steady
quality power supply voltage they are likely to trigger falsely. Since you use the same supply for servos
and the PIR this is very likely your problem.
OK I'm not sure if that was it. I did change the power supplies. So I gave the servos their rechargeable mobile battery pack and the nano I left on a USB cable from the wall adapter.
The first couple of times it fired without me moving again. But after that I decided to move out of the room and I was even ready to film it form outside the room to show you guys, but then of course it didn't move. So I guess that's that!
Thanks
The tiniest amount of movement may trigger them... it's really hard to sit that still!
Marciokoko I saw your post today, did you check if your PIR sensor is in re-triggering mode or in non re-triggering mode. In the non re-triggering mode the output goes on and off depending on the delay set. The board has a jumper that you need to change.
