How can I fix this issue?
Sketch uses 2260 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 222 bytes (10%) of dynamic memory, leaving 1826 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/AppTranslocation/62D8480E-C9F5-454B-91F1-41F51AA3D53E/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/AppTranslocation/62D8480E-C9F5-454B-91F1-41F51AA3D53E/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodemFD141 -b115200 -D -Uflash:w:/var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/arduino_build_692460/Pir.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/AppTranslocation/62D8480E-C9F5-454B-91F1-41F51AA3D53E/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/robynmartin/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodemFD141
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/arduino_build_692460/Pir.ino.hex"
avrdude: writing flash (2260 bytes):
Writing | ################################################## | 100% 0.37s
avrdude: 2260 bytes of flash written
avrdude: verifying flash memory against /var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/arduino_build_692460/Pir.ino.hex:
avrdude: load data flash data from input file /var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/arduino_build_692460/Pir.ino.hex:
avrdude: input file /var/folders/pv/n9shspvj75x48v66rtpkkwww0000gn/T/arduino_build_692460/Pir.ino.hex contains 2260 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.30s
avrdude: verifying ...
avrdude: 2260 bytes of flash verified
avrdude done. Thank you.
