So i am trying to stop my stepper motor when my PIR detect motion. But my motor is not stopping.
Here's the program:
int PIR = digitalRead(3);
if (PIR == 1) {
delay (2000);
else {
myStepper.step(1);
When i tried this but using a push button instead of the PIR, it worked. But with the PIR, it does not.
system
#2
What value are you reading from the PIR sensor? How is the sensor wired?
PIR reads 1 when there is motion and 0 when there is not.
The sensor has 3 wire, V+, ground and output.
system
#4
Which you have connected where?
Does? Or should?
Do you have a pulldown resistor to make certain that it does? Or does it incorporate one?
