Hell all, I'm messing around with a basic PIR sensor. The challenge I'm having is getting it to work properly. All connections are secure and PIR seems to get completely random input. I cover it up completely and sometimes it detects motion and sometimes it doesnt. I dont cover it and it will not detect motion at times and other times it will. I've adjusted the sensitivity and delay on the module and there seems to be no correlation. Module is brand new out of the package. Any experts out there have any thing I need to try?
* PIR sensor tester
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
