I'm using an MPU6050 (3 axis accelerometer, 3 axis gyroscope) and a complimentary filter to create 3d rotations of a box in processing without yaw. However when testing the filtered roll angles or filtered pitch angles separately there seems to be an unnecessary jump. When rotating from 0 to pi or 0 to -pi in pitch or roll it seems to work fine, but when I go beyond pi or -pi it seems to make an unnecessary 2pi turn and then continue correctly. Below is what I see from pitch angles in Serial Plotter. Arduino code and processing code are also attached.
Arduino Code:
#include <Wire.h>
const int MPU6050_address = 0x68;
int ACCEL_XOUT_H, ACCEL_XOUT_L, ACCEL_YOUT_H, ACCEL_YOUT_L, ACCEL_ZOUT_H, ACCEL_ZOUT_L;
int GYRO_XOUT_H, GYRO_XOUT_L, GYRO_YOUT_H, GYRO_YOUT_L, GYRO_ZOUT_H, GYRO_ZOUT_L;
double ACCEL_XOUT, ACCEL_YOUT, ACCEL_ZOUT, GYRO_XOUT, GYRO_YOUT, GYRO_ZOUT, dt, start, finish;
double gx, gy, gz, elapsed, angle_X, angle_Y, angle_Z, X, Y, Z;
const double pi = 3.14159265, alpha = 0.96;
Wire.begin();
Wire.beginTransmission(MPU6050_address);
Wire.write(0x6B);
Wire.write(B00000000); //enables wakeup mode
Wire.endTransmission();
start = millis();
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU6050_address,2);
ACCEL_XOUT_H = Wire.read();
ACCEL_XOUT_L = Wire.read();
ACCEL_XOUT_H = ACCEL_XOUT_H << 8;
ACCEL_XOUT = ((ACCEL_XOUT_H + ACCEL_XOUT_L) / 16384.00) - 0.02; //Last value is offset value
Wire.write(0x3D);
ACCEL_YOUT_H = Wire.read();
ACCEL_YOUT_L = Wire.read();
ACCEL_YOUT_H = ACCEL_YOUT_H << 8;
ACCEL_YOUT = ((ACCEL_YOUT_H + ACCEL_YOUT_L) / 16384.00) - 0.025; //Last value is offset value
Wire.write(0x3F);
ACCEL_ZOUT_H = Wire.read();
ACCEL_ZOUT_L = Wire.read();
ACCEL_ZOUT_H = ACCEL_ZOUT_H << 8;
ACCEL_ZOUT = ((ACCEL_ZOUT_H + ACCEL_ZOUT_L) / 16384.00) - 0.005; //Last value is offset value
Wire.write(0x43);
GYRO_XOUT_H = Wire.read();
GYRO_XOUT_L = Wire.read();
GYRO_XOUT_H = GYRO_XOUT_H << 8;
GYRO_XOUT = ((GYRO_XOUT_H + GYRO_XOUT_L) / 131.00) - 0.791; //Last value is offset value
gx = (GYRO_XOUT * dt) * pi/180.00;
Wire.write(0x45);
GYRO_YOUT_H = Wire.read();
GYRO_YOUT_L = Wire.read();
GYRO_YOUT_H = GYRO_YOUT_H << 8;
GYRO_YOUT = ((GYRO_YOUT_H + GYRO_YOUT_L) / 131.00) + 0.291; //Last value is offset value
gy = (-1 * (GYRO_YOUT) * dt) * pi/180.00;
Wire.write(0x47);
GYRO_ZOUT_H = Wire.read();
GYRO_ZOUT_L = Wire.read();
GYRO_ZOUT_H = GYRO_ZOUT_H << 8;
GYRO_ZOUT = ((GYRO_ZOUT_H + GYRO_ZOUT_L) / 131.00) - 0.7913; //Last value is offset value
gz = (GYRO_ZOUT * dt) * pi/180.00;
angle_X = atan2(ACCEL_YOUT, ACCEL_ZOUT);
angle_Y = atan2(ACCEL_XOUT,ACCEL_ZOUT);
//angle_Z = atan2(ACCEL_YOUT, ACCEL_XOUT);
X = alpha * (X + gx) + (1.00 - alpha) * angle_X; // pitch angles seem incorrect
Y = alpha * (Y + gy) + (1.00 - alpha) * angle_Y; // roll angles seem incorrect
//Z = (Z + gz);
Serial.print(X);
Serial.print(" ");
Serial.print(0);
Serial.print(" ");
Serial.println(0);
finish = millis();
elapsed = finish - start;
dt = elapsed / 1000.00;
start = 0.00;
elapsed = 0.00;
Processing Code:
import processing.serial.*;
Serial myPort;
String myString = null;
float X, Y, Z;
void setup(){
String portName = Serial.list()[1];
myPort = new Serial(this, portName, 9600);
size(500,400,P3D);
myPort.bufferUntil(10);
void draw()
background(0);
smooth();
lights();
fill(150);
stroke(100);
pushMatrix();
translate(250,200,0);
rotateX(X);
rotateZ(Y);
rotateY(Z);
box(100,50,50);
popMatrix();
void serialEvent(Serial myPort)
while(myPort.available() > 0)
myString = myPort.readStringUntil(10);
if(myString != null)
myString = trim(myString);
float[] val = float(split(myString, " "));
if(val.length == 3)
X = val[0];
Y = val[1];
Z = val[2];
Serial Plotter.pdf (29.7 KB)
