Pixelgroup is a library to group pixels in a RGB LED-strip. It is intended to be used in with a pixel-strip library like Adafruit_NeoPixel or Adafruit_WS2801 but can be used for any kind of backend.
It comes with 4 Pixelgroup Classes: PixelgroupBase, PixelgroupEaser, PixelgroupStrobe, Pixelgroup.
The most easy to use is Pixelgroup which can do set colors, color-fades, strobing and flickering.
The examples show the use of Pixelgroup with a neopixel-strip and a WS2801-strip demonstrating 2 ways: using the PixelWriter with Adafruit_NeoPixel and the PixelWriterInterface for subclassing Adafruit_WS2801.
#include <Pixelgroup.h>
// adafuit strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(20, 6, NEO_GRB + NEO_KHZ800);
// setup a pixelwriter
// make sure rgb order is correct (default: GRB like neopixel)
PixelWriter pixelWriter(strip.getPixels(), (uint8_t)strip.numPixels(), PXW_GRB);
// create pixelgroup
// instanciate with pixel indices
// argument 1: amount of pixels (e.g.: 3)
// argument 2..n: pixel indices (e.g.: 0, 1, 2)
Pixelgroup thegroup(3, 0, 1, 2);
// begin neopixel strip
strip.begin();
// setup a callback for "show" function in pixelWriter
pixelWriter.setShowFunc(showPixels);
// manipulate group
// demonstrate available functions
// set pixels
// argument 1: amount of pixels (e.g.: 4)
// argument 2..n: pixel indices (e.g.: 4, 5, 6, 7)
thegroup.setPixels(4, 4, 5, 6, 7);
// clear the group
thegroup.clear();
// add pixels
thegroup.addPixel(3);
thegroup.addPixel(4);
thegroup.addPixel(5);
thegroup.addPixel(6);
// remove a pixel
thegroup.removePixel(4);
// set some colors, write them out
thegroup.setRGB(255, 0, 0);
writeGroups();
thegroup.setRGB(0, 255, 0);
writeGroups();
thegroup.setRGB(0, 0, 255);
writeGroups();
// setup fading of group thegroup
thegroup.setFrom(255, 0, 0);
thegroup.setTo(0, 0, 255);
thegroup.setLoop(EASING_LOOP_BOUNCE);
thegroup.setDuration(3000);
thegroup.setEasing(true);
// set strobing of thatgroup
thegroup.setOnTime(600); // in ms
thegroup.setOffTimeSec(0.1); // or in sec
thegroup.setStrobing(true);
// flickering?
// randomly flickering pixels in group
// value defines flickersteps
// the higher the number, the longer it flickers
thegroup.setFlicker(20);
// need to tick each group for animations like fading, strobing, flickering...
// tick pickelgroups with same timestamp (so the animations are in sync)
unsigned long _now = millis();
// tick this group with timestamp
thegroup.update(_now);
// strip only gets written, if pixels are dirty
writeGroups();
delay(20);
// callback function for pixelwriter
// only gets called if pixelwriter is dirty...
// pixelwriter is only dirty, if something changed in pixelgroups
void showPixels()
strip.show();
void writeGroups()
// paint the group to our pixelwriter
thegroup.paint(pixelWriter);
// we know we have set a callback function
// can be tested with: pixelWriter.isShowFunc()
// this will call our callback-function
// pixelWriter is taking care about dirty state
// only calls callback function if pixelwriter is dirty
pixelWriter.show();
