Hello,
I wanted to reuse two Pixmob Wristbands, that I have from the Prolight + Sound Expo this year. I found out, that Daniel Weidmann tried this project and recorded some things using a flipper device (GitHub - danielweidman/pixmob-ir-reverse-engineering: Hacking the PixMob infrared (and now also RF!) protocol to enable control of PixMob wristbands at home.). I found another project from a guy on hackster io (Reusing PIXMOB Waveband Without Flipper Zero - Hackster.io), that does this project with a B-L072Z-LRWAN LoRa Module. Because of an other project, I had the nRF905 laying around. My Question now is, if theres an Opportunity to create an OOK Signal with this Device.
I would be happy, if there are some nerds here that respond and could help me
Thanks!
Don't be lazy, open the data sheet and you find the answer.
Anyway, you make your life easier with $2 CC1101 module
Thanks for your respons. The datasheet says nothing about an OOK signal. Thats why im asking. Also thanks for your tip. I found out, that many other people are using the CC1101 module for this project.
Thank you anyway!
That's why I recommended it, lot of useful code available. And nrf905 is only gfsk.
