So if I have a servo moving constantly but in 1 sec it plays a tone but then in 10 secs, it happens to play the tone while the servo is uninterrupted.
This is not at all clear.
How do you interrupt a servo? Do you mean mechanically restrain it?
That would cause damage to the servo. You normally have no indication that a servo is blocked that the code can access, unless you fit some sort of feedback sensor like a rotary encoder.
Most tone generating libraries are blocking code so that will prevent a servo from working anyway.
So what do you actually want to do and why?
