I wanted to make an LED-cube, so i bought a bunch of PL9823's (adressable RGB-LED's, these)
Then I did everything as shown in this YouTube video.
- installed the fast-LED library
- set up the LED (shortest leg to pin3, longest leg to GND, leg inbetween to +5V)
- uploaded the BLINK-example (see below)
- nothing happened, the LED continuously shows a bluish-green light ...
This is the sketch:
#include <FastLED.h>
// How many leds in your strip?
#define NUM_LEDS 1
// For led chips like Neopixels, which have a data line, ground, and power, you just
// need to define DATA_PIN. For led chipsets that are SPI based (four wires - data, clock,
// ground, and power), like the LPD8806 define both DATA_PIN and CLOCK_PIN
#define DATA_PIN 3
// Define the array of leds
CRGB leds[NUM_LEDS];
   // Uncomment/edit one of the following lines for your leds arrangement.
   // FastLED.addLeds<TM1803, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<TM1804, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<TM1809, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
   FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
   // FastLED.addLeds<APA104, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<UCS1903B, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<GW6205, DATA_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<GW6205_400, DATA_PIN, RGB>(leds, NUM_LEDS);
  Â
   // FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<SM16716, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<LPD8806, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<P9813, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<APA102, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<DOTSTAR, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<SM16716, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<P9813, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
   // FastLED.addLeds<DOTSTAR, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
 // Turn the LED on, then pause
 leds[0] = CRGB::Red;
 FastLED.show();
 // Now turn the LED off, then pause
 leds[0] = CRGB::Black;
 FastLED.show();
So... I'm pretty sure I did everything right, but then again... why doesn't it work?
