Placing Arduino Due in Magnetic Field
I am testing some of my digital compasses by placing them in a dycome. I'm using I2C to communicate with the compasses so I will need to keep the Arduino relatively close to the sensor, which means it will be in the dycome with the magnetometer.
Is there any reason I should not do this? I will only be applying a magnetic field strength up to 400mG.
I don't think 400 mG could harm your board if I refer to this:
http://www-ehs.ucsd.edu/LBCI/LIPA_Magnetic_Field_Levels_Around_Homes.pdf
But due to EMI, the board or the sensor could hang:
Consider 10 or 20 ohm series resistors ( you can try up to 120 ohm) between the Due and the bus (one for SDA, another for SCL). This will attenuate the glitches leaving your Due, and eventually detect timeouts to reset the I2C bus if necessary. You will find a I2C bus reset function in the DUE sub forum.
Thanks for the reply, that's about what I figured, I'll do a bit more reading but it looks like it should be fine.
Just curious, what is a dycome?
Perhaps you could increase and decrease the magnetic field gradually in order to induce less current flow in the arduino circuitry?
A dycome is a machine that lets you apply a magnetic field in any direction you want, including inclination. I don't think they're very common anymore but they're useful for testing magnetometers.
Here is a picture of one that is very similar to the one I will be using:Paleomagnetic laboratory | Department of Earth Science | UiB
